Precision Matched Vishay IRFP240 IRFP9240 MOSFETs and IRFP240 MOSFETs
February 2023 Stock Update
IRFP240 - In Stock (~850)
IRFP9240 - In Stock (~100) - Looks like these will be my next bulk buy....
Vishay IRF9610 - In Stock (<50)
Harris / Fairchild SFP9610 - In Stock (600+)
LIMITED STOCK / DISCONTINUED
On-Semi FPQ3P20 - In Stock (~20)
On-Semi FPQ3N30 - In Stock (~30)
March 2023 Stock Update
IRFP240 - In Stock (~650)
IRFP9240 - In Stock (~150) + not yet matched (200)
I was down to 8x 240’s. Matched another 1,000
rthatcher,
I google search for matched mosfets has brought me to this forum.
Project 1: I want to rebuild the power section of an Ampeg SVP1600. It uses (5) IRFP9240R (5) IRfP240R MOSFETs per channel (2) . One side (Ch B) is not working and the level indicator flickers randomly. I'm shooting in the d.ark but would like to put new mosfets all around (qty. 10 each type)
project 2: Mackie M1400i (4) MJL2113 (4) MJL 2114 per channel (qty. 8 each type) with a similar problem; one channel out
Do you have matched sets for these amps?
DM me,
Thanks!
Appx 850 International rectifier IRFP9240s are now matched up. I was down to less than 10 of my prior batch of Vishays.
Next matching session will be some Harris / Fairchild 240s and 9160s. There’s no rush yet because I have from my last matching session.
I think I may have a lot of Harris 9240’s that I bought that I’m going to match at some point, too. I think that was a smaller batch of ~100.
March 2024 Stock Update
Vishay IRFP240 - In Stock (~50)
Fairchild IRFP240 - In Stock (~1400)
International Rectifier IRFP9240 - In Stock (~900)
Vishay IRF9610 - In Stock (~40)
Harris / Fairchild SFP9610 - In Stock (~350)
On-Semi FPQ3P20 - In Stock (~15)
