Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
Hell no but! Just over the holiday weekend, I Finally created a stain color that I like😃 . Theres nothing like having something you like but not getting the aesthetic right.
I have minwax oil stain, minwax tung oil and turpentine. Minwax poly and Deft spray lacquer. Theres a talented wood guy I found online and conversed with
(Heres his DIY project)
Who gave me some good info on staining. The gist of it is to thin/dilute the stain and apply many, thin coats, until color is achieved. First maybe Stain and then on to Tung oil which builds up into a luster after enough coats, so I hear. After that I may wipe on poly and finish with the spray lacquer.
I think in order to help dummy proof the stain process I will go for a higher dilution. This should help me cover surface, faster, without flaw, as I foresee the need to do both horns inside and out, for each layer I do.
I'd like to get a nice animal hair paint brush. Between that and wiping hopefully I'm on the right path
Reactions: D1sco
camplo, spraying stain is a good way to even your colors over blotchy wood (if you have the equipment) use a oil base stain mixed down with thinner, experimentation is involved to get the mixture blend and air pressure set, small nozzle (believe I use 1.3 mm for that) then practice a little because spraying stain is like artwork alway keep the air jet going and move fast, while its still damp come back over and blend the lighter spots with quick blips of spray while still sweeping the can over the entire length with the air jet always going.
I reckon if you’ve never used an air sprayer that might be greek but its not that difficult if you practice a little.
Reactions: GM
I looked into it and a decent spray gun is relatively cheap.
I wanted to start with very diluted stain already. Sounds a thin medium is also welcome by a sprayer. Thanks again guys for taking the time to share your thoughts!
I will have to wipe the inner most of the throat , with a cloth on a stick or something rather.
Reactions: mountainman bob
Yes, same thing.
…and your compressor setup might also have the separator; here is the little gun-connected one I use:
https://www.harborfreight.com/oilwater-separator-68246.html
Tip: always start your spaying in the “air” before crossing onto the work-piece (and stopping off of the work-piece) with the typical side-to-side spray-motion. (Obviously with something/tarp behind the work-piece to catch the over-spray.)
A more Acoustics related question
Phase Pattern Flip - How does this relate to perception? I've read people suggesting that they can perceive this and opted to not use a particular horn/waveguide because of it. I am wondering if it is more perceptible in one particular spectrum versus the other etc etc...
Kind of obvious (to me anyway) when looking at an extreme version such as Altec's 511/811 sectoral horns, i.e. note that from ~1800 Hz - up is the Altec 800 series driver's small conical horn and the 511's round to rectangular adapter that's 'pinched' down to the expo flare.
This was no doubt in my mind the main reason why they opted for a 1200 Hz XO in their Model 19 'flagship' that many (still) believe is the best overall performing 'HIFI' speaker regardless of (Altec) design type.
Reactions: Ro808
I experienced pattern flip with the mid/high biradial tractrix horns for the BMS drivers. When the mouth is horizontally much wider than vertically, the vertical directivity changes suddenly, below a certain frequency treshold. This is perceivable. Round/petal horns do not suffer from this.
Please explain what exactly you have perceived when doing what? And please explain the term suddenly you have used. What was differently to your strong beaming round horns?
