Graham Holliman Velocity Coupled Infra Bass Speaker?
Which model? Define 'big' as to me anything < 30 ft^3 is acceptable. Any height, etc., dimension limitations? Plain ol' TL or.......? Desired XO point?
GM
Big for me is >1m3
Stereo subs a must.
The driver model is the JBL 2245H 30 cu ft would take 2 of my drivers, with 2 cabinets per side x over point would be 50 Hz maybe a little lower.
TL is a possibility, likely I would just use one of the bass drivers per side?
I did even consider an Isobarik config in a low Q=0.5 sealed box
Hi all!
I plan on doing my master's dissertation about the Graham-Holliman subwoofer! After all those years it's difficult to get a proper idea of the performances of the speaker. Can anyone here post information he/she has about this type of speaker:
Suggestions for built
Summary
Drawings
Frequency responses
Thank you so much in advance!!
Igor
I can't be of any help other than linking the patent application
https://patentimages.storage.googleapis.com/7d/43/05/8700aabd258b78/GB2037534A.pdf
Hmm... I'm trying to figure out if that design at the bottom left can be modeled using Hornresp. Using segments S1-S2 could represent the volume V. S2-S4 could represent the path from the back of the driver to the front, Vtc and Ltc used to represent the small volume in front of the driver....
Maybe I'll have a look at it later....
I finished drawing the enclosure in a CAD program. I will start building the cabinet in the coming weeks (as I am waiting for plywood sheets to arrive).
Next up is the drive-unit.
What T/S parameters of the drive unit are important when looking for a suitable drive-unit for this particular type of enclosure?
(I am building the 10" version)
in this thread I've seen the following drivers being used:
-Richard Allan 10"
-Peerless XLS 10"
Any tips for choosing the drive-unit would be more than welcome!
Once my built is done I will bundle all information available in this thread, do measurements, compare them to the existing data and make an academic report of it!
Whatchu think?
Audio frequency - Wikipedia
Interesting site, click on sound the file for 24cps, these are low piano notes, but the 16 or 8 cps no click available you need a large pipes, religious buildings to house. Bringing the people inside to their knees. This was done with air blowing across pipes before woofers were thought of.
A little box with a paper cone 10 inch driver? 18 years since the 1st post+Home Depot full of lumber+ plans =no one did it yet?
If I had to build a 7 or 8 cps 140 dB horn I would rig four of these size woofers (forget about bass reflex) to a 10 mile long exponential horn.
My caregiver won't let me buy Wood for a speaker box. So here's my cardboard and gorilla tape infinite baffle... With a pillow just touching the bottom of the baffle it actually has a little bit of bass. These are Bose acoustiMass 10 replacement woofers. They are six inch drivers in the picture.
Reactions: GM
Edit:;; if you turn it up there's a bit of bass!!! I need a LOT of bass at low levels. It ALMOST seems like it could have more bass but I don't want to sacrifice sound quality at it has that... But...my housemates don't want to hear my stereo out in the living room...
