I’m starting this build because I’m a newbie and I would like to ask some simple questions on how to build speaker cabinets.
Today, together with my friend, we did some trials on a junk piece of wood.
Is this correct, or the 45 degree should start from the inner part of the speaker?
Another question. For internal points like the bottom of the internal V of this FHL (image taken from the site):
I'm thinking to glue both the inner and the outher of the V vertex, in order to avoid any leakage.
Is it correct? Any better method?
Thanks Scott.
What about the 45° behind the speaker, is correct the way it's done in the photos with junk wood?
I did the FHXL with 45° all around the back side of the speaker hole, and here I would do things better.
Build in progress!
Some photos of the work in progress of the Silbury with the MA10.3
Those nutserts work great and are better than T nuts. The brass ones should use brass bolts too. If you mix metals there is a galvanic reaction that can weld the bolt to the insert. Much better than just screws into wood as they can be removed and reused without issues of the wood getting torn up.
@Scottmoose @planet10
I forgot to ask one thing: I bought the MA10.3 from a guy that used them in open baffle speakers, and I noticed both have a small dent on them:
What could be the cause of that dent?
Is it safe to use them? Is there anything I can do?
Thanks!
Thanks!
Hello Dave.
It is not possible to repair when such damage has occurred?
Is it an injury caused by playing too strong? Or without any box?
- Full Range
- A new pair of Silbury speakers: newbie questions
