Mister 45, everyone is allowed to have his own opinion. You are the one who is trying to hijack the thread with your superiority. Though it is not informative, but it would be nice if you had a respect for others. If you have objections to someone’s views, you are welcome to present your arguments.What language? Do you realize that EVERY thread talking about transformers you keep saying always the same stuff even if it is not relevant?
I asked you to show with numbers or kindly stop hijacking the thread. You can't do it. Q.E.D. Now you should just stop because I don't care about your opinion. I don't need your advice because I have a number of Japanese transformers of different kind, including PSU transformers not just OPTs.....plus Lundahls, NP Acoustic
This is only MHO.
My opinion is the contrary Mr AndreK: you are the one that hijacked the thread in the first place thinking to be superior. You wrote:
Did really you think that you needed to explain anything new? Those formulas are from old books and even if someone doesn't know the theory of electromagnetism or exact definitions is irrelevant in practice because they are not necessary to make a good transformer. Finally, if you thought you needed to explain you would just do it instead of writing something that doesn't make the point, because Bdc will increase if more turns also when the practical formula is used until it will start saturating.My argument is, Bdc has nothing to do with L, and the more turns, the higher Bdc, that is all for now, if you want me to elaborate on that I am there for you., Thank you.
Andre.
I can't understand the fuzz over transformer parameters. EI, C-core, air core or wooden core, perfect square, ringing square, low or high distortion, as long as the builder, customer, or for both requirements are brought to satisfaction, what's the big deal?
The big deal is that different cores have different properties; different winding schemes have different properties and so on.
I don't think you start winding when your customer asks for a wooden core transformer, so his decision depends on the advice you will give him within the possibilities setting the margins (but you know that....).
I don't think anyone denies it, but for what reason should we fight over about it?
There is no reason to fight about it, but normal conversation becomes very difficult when one among us continues to create an atmosphere of disrespect towards fellow members.
Look, you don't really know what I do know, and what I don't.My opinion is the contrary Mr AndreK: you are the one that hijacked the thread in the first place thinking to be superior. You wrote:
The argument started when I said L has nothing to do with Bdc, except for convenience.
And that is exactly what I said, Bdc will increase with the number of turns, did not I?
You admitted you never wind transformers yourself, so you just throwing expressions and formulas, which is fine, how about common sense? How about your own experience? How about your own findings, do you have anything to share?
Sorry, I am getting too emotional here.
I am afraid you did not talk about convenience. You were arguing against a formula because you thought it was wrong. I was not born yesterday!
I said I used to wind my transformers, I know how to make them. Sorry if I don't post pictures but I am not a social network guy who takes pictures and posts everything he does in his private life to show off. By the way, until you kicked in with your un-necessary comment I did not post. Can you read? Probably not, as from your own admission, you are getting emotional. But make no mistake, it's nothing personal.
See what I said?OK, yes I can see your point, inductance in the expression for Bdc calculation is only to make the calculation easier since it has number of turns and other staff inside of it. What I was trying to say is,
The inductance of itself has nothing to do with Bdc, only current (Idc), number of turns and permeability.
L is the property of the inductor, Bdc is not. L does not depend on the current, it exists with and without. Bdc does not exists only without Idc applied, so it depends on the Idc and some of the inductor’s properties such as number of turns and permeability of the core if it is there.
Though L also depends of those factors, it does not mean it has anything to do with Bdc.
L is used in the Bdc calculation just for convenience.
I am pretty sure, you guys know what I am trying to say.
Thank you,
Andre
45, it is pointless to argue with you. No matter what, you will try to reject the obvious.
Simple example:
R=E/I
does I depend on E?
yes, but it does not mean R depends on E.
Is it simple enough?
Yes, it is better that you stop arguing because you wrote that after I did some maths to show where those formulas were coming from. No one was talking about dependence or assuming a particular meaning except you. Your example is pointless and actually highlights your attitude.
If you want I can show you how to derive the expression for magnetic field and induction starting from the general Maxwell equations. If I were really as you would like to believe I would have done that.
That relative permeability of 440, is for refrigirators power transformers... 🙁Air-gap for 60 mA and required inductance would be 0.18 mm (i.e. in practice 0.1mm spacer holding laminations tight). Effective mu will be around 440 with my M6 laminations.
So:
L = 26H (small signal like 3 Vrms at 50Hz)
Bmax= 0.8T at 30Hz
Bdc > 0.4T
Bac < 0.4 T for 200V RMS
Rprimary =140R
Rsecondary = 0.4R
Insertion loss with 300B = 0.57 dB
Leakage inductance = 4 mH
Sorry bu these laminations are not for audio aplications.
In conjunction with standard window (small space) for windings will lead to rationalize the music type can be listened with this SE amp...
Try with rel. permeability of standard 800...
It's a SE transformer, low permeability can be required. What's the big fuzz over 440 permeability?
440 is the permeability with small signal. It will increase with signal. Try to make a real audio transformer instead of using a transformer from a refrigerator. Then we can talk.That relative permeability of 440, is for refrigirators power transformers... 🙁
Here is one example:
https://tango-trans.com/wp-content/uploads/catalog/X-10S.pdf
it's 65H for 1 mW and 80H large signal. The change happens for EVERY transformer with ANY core type. It depends on the ratio between aig-gap and mean magnetic path length, core permeability and actual induction to which it's referred. So in some cases there is more change and in others less.....
No that is not true...440 is the permeability with small signal. It will increase with signal. Try to make a real audio transformer instead of using a transformer from a refrigerator. Then we can talk.
IF somehow magicaly it is true then the amplifier will have dramaticaly different transfer in the low end with 1W and 10W power...
BUT IT IS NOT THE CASE
You can easily prove to yourself by measure the device with small signal input and large one.
BTW i made some output transformers long before you aplied to this forum 😉
(Mine for 2A3 had -3db 8Hz/100Khz, but it winded on brand VAC cores for audio applications.)
Please check the [units] in your formulas they shoud be compatiobile, same from each sides of equations...
Tango X-10S....good transformer. HiB silicon steel c-cores. Forget to make something comparable with M6 EI lams.
No offense, but your language consists of petty low-level nagging.
And yes, permeability changes with excitation level, so transfer characteristic will vary. If you deny this fact, I wouldn't be bragging on transformer knowledge if I were you.
P.S. It it also measured, I believe Menno van der Veen wrote an article on this one. You can google that.
And Your amploifiers have no bass - please give us some simple real measurements BUT with phase, and from 1Hz start
thanks
thanks
- Tubes / Valves
- Show your transformer work (gallery)
