About Monarchy mono
Hello !
I would like to understand how to build a balanced cable to bring Monarchy SM70 from stereo to Bridged (BTL) (have a pair
May be a small picture would help to understand what kind of connect is at the other end of crystal cable.
Thanks for any help
Isn’t there a switch?
It was a long time ago but i did get the opportunity to play with a pair. We ended up just uaing 1 channel in each of the 2 amps. Only 25 w, but 5 would have been enuff.
or it could be just drive it with a balanced preamp (if XLR wired that way).
dave
@wcwc
The upstream source is a SMSL SU9 Dac, can output unbalanced or balanced flow.
But I don't want to use digitally volume , because of dynamic lost.
So, I "diyed" a small box with fet buffer and volume pot unbalanced to 2 channel unbalanced Monarchy
I've some Jensen, edcor, Lundahl transformers, I'm gonna build a symetric converter.
@planet10
The schematics are top-secret defense, never seen any information,
"two top red posts are live in conjunction with the left RCA input "
In BTL mode, like initial picture, only "hot" (red) outputs are connected, 2 channels in fonction, opposite phase , the question is "who inverts the rca input"
Thanks ! i'ts late there, (1;20 AM), tomorrow will be another day
