Yamaha CA-410 Bulb Repair Advice
I'm working on an old Yamaha CA-410 and can't seem to get the display bulbs working. No other issues. Can anyone offer any advice?
D420 is not the supply rectifier for the display bulbs
D415 an D417 are the rectifiers and there is only DC supplied to the display bulbs. This supply voltage is the same supply of speaker delay/protection circuit. If the amp works with sound output then this supply circuit is OK.
The problem maybe broken PCB copper trace or bad soldering pads of these display bulbs, you may try soldering the display bulbs to the nearby connected component pads directly.
Reactions: SquireTrelawney
There was no DC voltage across the capacitor feeding the lamps ... why solder them in to a dead circuit.
Your trace makes the DC feed more realistic.
