Anyone ever try adhesive circuit board mounts? Would eliminate drilling holes and trying to get them lined up right.
I have never tried tapping my own but find your suggestion interesting. Do you have a link for where you purchased yours? Thanks!No, I haven’t. But using speed taps chucked in a cordless drill will make your project completion very speedy.
Here’s one option
aiyun 6 Pack Drill Tap Metric M3-M10 Tap Set Metric Drill Taps for Steel Aluminum, Sheet Metal and Other Hard Metal Thin Plates(HSS6542) https://a.co/d/bnT5MKO
I’ve been using this type of tap for years. Just use some 3-1 (or cutting oil) and you will be tapping your chassis like a pro at Superman speed.
When I'm drilling holes for mounting a circuit board, I use the bare unpopulated board as a template for laying out the holes. I put masking tape over the metal, place the board directly on the tape and then mark the hole locations.
From a philosophical point of view, I enjoy the audio DIY process so I'm in no rush to finish the project. It's not like a house reno project where there are time pressures. I find that without time constraints, taking things slowly and working things out is enjoyable. It's kind of like Zen and the Art of Motorcycle Maintenance.
Not trying to change your mind but adhesive board mounts are commercially available, not a matter of making them yourself.You don't want the pcbs to loosen, shift, or fall off. Adhesive is not a good idea.
And more permanent mounting like epoxy makes servicing difficult, or worse.
https://www.digikey.com/en/products/detail/würth-elektronik/709264000/9488225
Just found this on Reddit:
"I use velcro every day in commercial installations. Not only is the ability to attach/deattach super convenient but Velcro is the best vibration resistant bonding method. The more you shake it, the better it holds. I get funny looks now and again from the younger client site technicians but the older guys love it."
Not ready to endorse that but it fits this thread.
Of course. I've used those for experimentation for many years, but the adhesive dries up and the mount falls off,
especially in a hot environment. Not for serious work.
I have had really good luck with these:
50 PCS Circuit Board Plastic Standoffs Mounting Hardware,Motherboard Standoffs Foot Offs and Screws :
https://a.co/d/1IpSlKi
Ed
Ed
- Circuit Board Mounts
