I'm looking to reduce gain in this preamp
Barry NJ,
I believe we might have solved your preamp problems quicker, if you originally said in post # 1:
The problem is "the buzzing/spitting noises" (Your Post # 78).
I can not remember if you ever said that in a Post between # 2 and # 77.
My 77 year old mind's memory is not real good.
Do not assume that the cause of "the buzzing/spitting noises" is only caused by high gain.
Might be true, might not be true. Ground loops, poor design, and a few other causes.
Assuming that in your case: high gain is the only cause of "the buzzing/spitting noises", Then . . .
Changing from a high gain 12AX7 SRPP input stage, to a 12AU7 SRPP medium/low gain input stage is simple, even if your circuit is all on a PCB.
Changing two resistors in the input stage, and changing one in the B+ to the input stage should do the trick.
You want to run a little more current in a 12AU7 than in a 12AX7. If your preamp is a quality design, it can handle the slight extra B+ current.
And, it is easily and completely reversible, if you later need to sell the preamp.
Happy modifying!
If you are unwilling to "ruin" that commercial preamp by doing as simple a modification as that, then sell that preamp.
Then purchase one that is more suited to your system.
I hope you solve your problem soon, and get back to enjoyable listening!
Just my opinions and experience.
Your Mileage May Vary.
Thank you very much!
This sounds exactly like what I was looking for, a simple parts swap that could easily be reversed if it doesn't work out as well as I'd like.
Would you be able to provide the resistor values, and their positions in the circuit based on the ID codes on the schematic I'd initially provided?
While infuriating Jean-Paul would be fun, that's out of my budget, though this holds potential...
https://www.schiit.com/products/saga-2
That is probably a device that will bring what you want. Making well thought out choices will never infuriate any sane person I guess. It sure checks many boxes and the volume control is way better than the usual. It can be used actively and passively which is nice. I just hope Schiit designed it with muting at power on/off.
With solid state sources and solid state amplifiers this Saga+ would be one of my choices (FWIW). The price is low for a western build device. One can not build that DIY for that price with relay based volume control, remote control and also a nice looking casing.
While I haven't heard the Saga+ I've read comments from owners who say the buffer mode, which includes the tube, doesn't really sound any different than the passive mode. And, if you read the description on their website, they make no claims that the tube alters the sound at all. They only say that it's handy if you need to drive long cables.
So if you're looking for something that offers "tube sound", the Saga+ doesn't seem to and $400 seems steep to me. But then I'm cheap.
If you don't care about "tube sound" and just want the convenience features I'd suggest this little non-tube Chinese preamp. I bought one a few years ago simply for the convenience features. At the time it was about $60 shipped but, of course, prices have gone up. Looks like ~$100 now.
I mainly wanted something with remote control volume and mute but it also has 3 analog inputs and bluetooth. It does have gain but the volume adjusts in 0.5db steps and you have to turn it up a lot before the gain kicks in, so there's plenty of adjustment range. The volume control is "digital", not a motorized pot, but I have no idea if it uses relays or what. It's quiet and has been totally reliable. And it's 1/4 the price of the Saga+.
https://www.ebay.com/itm/293406152320?hash=item44505e9680:g:s6kAAOSwJBdeDwxv&amdata=enc:AQAHAAAAwKiNdbM968BRqGoaqpUk6RkoF7QjaEnKF/rTsBgYpQjwxSJWQMcjN6rajZ9um39y+f/DeLi0qO/I9cVYOAoZmfwn46VNmqnlCTqg+JCA1YqeXnATEChIRP+XjvxQxcPPIAqWlq01YmtqsK9oG51Mx6B5u0kFhdyjkU9S5NxDILGFYxC23KRm2ivz1MYlwBuWeKL4p6GiSr4eG1LclRoO0h+wGH7n9RHI5j1mnNIx8129i7PDuASMY7COBHW0K2cejA==|tkp:Bk9SR8q5kKvqYQ
If there MUST be a tube in it then look at low gain devices which are not standard in the tube world.
This is what I did when I built a preamp and wanted some tube character. The only tubes I considered had a mu (amplification factor) under 10. You'll probably have to build one yourself, though. Most commercial designs use tubes that are currently being manufactured. If you build one yourself you have many more choices, which allows you to start with the right tool for the job.
Reactions: Barry NJ
Barry NJ,
1. First, carefully do a few measurements, before modifying:
(Note: carefully means safely, and also means not letting the meter probes slip and short something)
DC voltage at the + of 3C2 (that also connects to 3R5 and 3R11).
DC voltage at 3R2 and 3R3.
DC voltage at 3R4 and 3R10.
2. Now, replace the 12AX7 with a 12AU7.
Again, carefully do a few measurements:
3. Listen to the preamp, and see if there is any improvement (less buzzing and spitting noises).
Is it good enough now?
Report the voltages for 1. and 2., and the listening test 3. above.
Based on those measurements, and the listening test, we will see if any resistors should be changed.
So currently...
3C2 = 283v DC
3R2 = 1.17v DC
3R3 = 137v DC
3R4 = 144v DC
3R10 = 147v DC
Note, I'll need to acquire the parts before I can swap them in, don't have those type of things handy here.
I'll order from Mouser or Digi-Key to hopefully ensure I get quality parts.
Reactions: Ixnay
So, do magic pixies come into the system after a few days and just fix problems?
No changes made, and the noise is pretty much gone(?) I can hear a little something with my ear against the speaker grill, but there are no longer any nasty noises heard at the listening position...
I did order some NOS RCA 12au7 tubes that should be here in a couple of days, and I'll see how they effect the gain and overall sound of things.
12au7_tested by Barry, on Flickr
From the air 🙂 I wish I could ignore issues like that. You have buzzing/spitting noises that now do not occur. These probably will return. What will the comment then be? It is still quiet?! Do you seriously think that issues solve themselves? That would really be splendid!
Reactions: Barry NJ
Barry NJ,
When you get your 12AU7 tubes, just plug them in to the 12AX7 socket.
Then listen.
Gain OK, Sound OK, hum OK, noise OK?
Problem solved?
Done.
Or if not, then . . .
Is it more distorted, versus with the original 12AX7 tubes?
You might change 3R5 from 5k to 2k.
After that,
You also might see what happens if you change 3R4 and 3R10 from 100k to 47k.
Remember, these things may change the sound, more to what you like, or less than what you like.
Reactions: Barry NJ
So currently with 12ax7 tubes...
3C2 = 283v DC
3R2 = 1.17v DC
3R3 = 137v DC
3R4 = 144v DC
3R10 = 147v DC
So, 12au7 tubes installed into 12ax7 sockets...
3C2 = 272.7v DC
3R2 = 4.85v DC
3R3 = 123.1v DC
3R4 = 134v DC
3R10 = 136v DC
Listening was horrible!
The tubes seem to be so microphonic to the point I was getting feed-back.
Lightly taping the preamp caused a clearly audible ring from the speakers.
Could it be that the tubes are bad, or is it a reaction of the circuit to the different tube type?
P.S. I'll add that the gain was now much more reasonable, with normal listening levels reached with the volume knob at about 11 o'clock. But the microphonic sensitivity was ridiculous. I didn't really get to evaluate any of the other audible characteristics for fear of entering a bad feedback loop and damaging something.
Barry NJ,
Then listen.
Problem solved?
Done.
After that,
Okay, so some GE5814 Triple Mica tubes installed and I think all is as it should be. The 5814 tubes seem to be running a lot hotter than the 12ax7 tubes did, just by the evidence of their glow if nothing else. The tube on the right has less silver coating on the top, hence its more obvious glow. But the 12ax7 tubes had no discernable glow when they were in there, and the rear 12au7 doesn't glow either...
2023-04-16_09-01-06 by Barry, on Flickr
The 12AU7 and 5814 will draw a lot more plate current, versus the 12AX7 plate current.
That is the main addition to the heat you noticed.
Example; 3R2 1.5k Ohms, and the voltage across it is:
With a 12AX76 1.17V; that is 0.78mA
With a 12AU7 4.85V; that is 3.2mA (and with the 5814, 3R2 is probably about 4.85V too)
4.1 times more current, 4.1 times more heat.
The 12AX7 and 12AU7 filaments wired for 6.3V draw 300mA each tube.
The 5814 filaments wired for 6.3V draw 350mA each tube (not a lot more current).
Reactions: Barry NJ
Thank you, your guidance has been very helpful and it is greatly appreciated!
Are you still looking to reduce the gain in this amplifier?
It is hard to change the schematic since it is all mounted on a circuit board. Otherwise I might propose to change it from SRPP to MU-Follower.
Swapping out the input valve/tube from 12ax7 to 12au7 might still work, so stick with 6A3sUMMER's help here.
Another option would be to add some global negative feedback to the circuit. I never did it for SRPP but it is an option, and it does work nicely. I would take the feedback loop from after the cathode follower's output cap through to the input (if it can be done).
Morgan Jones has a nice write up on this I think.
Ian
Reactions: Barry NJ
Another possible issue I didn't see discussed in this thread is over driving the preamp. I built a 12AX7 based preamp feeding a 12AU7 crossover chain and with standard 2v input levels the 12AX7 input stage was producing distortion in the 4% range. I had a very lossy bandaxell bass/treble control circuit and needed the gain. Not one of my better projects, both sonics and measurement wise
Reactions: Barry NJ
