Restoring My Rek o Kut B-16-H
Here are some pictures of it
I will post more as i get more into it.
Reactions: Pano
Read down at the bottom, you'll have to contact him since you don't have the original. He said he had the info but you never know. Had I known, I would have had him spec mine out so he could make them (if he doesn't have measurements). If I didn't have mine up for sale I could have sent it to him. Maybe when he had mine a month ago he took some measurements for the hub. Or you could buy my table and I'll bring it to you (or close).
https://www.thevoiceofmusic.com/catalog/phono_wheels_turrets.asp
Special situations:
If you do not have the old part, and it is required to be mailed in, Contact us before ordering.
If there is no replacement for your wheel, it can be custom rebuilt (normally 4 weeks timing). Contact us for order information.
Apparently someone tried to mount that other collar and made another hole for it.
Butcher it
I found that collar that says 160 on ebay
That seems to be the right collar
It lines up perfectly
Now i have to find out what i will fill it with before i paint it.
