Yamaha R-3 No Bias L-channel
Replacement with 5.5k is fine.
If I'm interpreting correctly, the 0.013V reading is the junction of R267 and R269? The problem lies there, I believe. Probe directly on the the two resistor leads on either side of this junction. I think you'll find different voltages; if they turn out to be the same voltage, probe at "bottom" lead of R269 that connects to the B- rail. There seems to be an open path somewhere between B- and the base of TR125.
That's correct: 0.013V reading is the junction of R267 and R269. I measured this junction with the red lead of the multimeter and the black lead to the ground/chassis.
When i measure R267 at both sides with the multimeter i get 0.75V. For R269 it is 41.6V
I compared to the right channel; the junction of R267 and R269 should indeed be 21V. (at R268 R270 it is) Inspected the PCB very well for damaged leads but i don't see any. Measured from Base of TR125 to all points and no open connections. Could capacitor C237 47uF/25V be fault? Think i'm going change this one... I don't have a clue why voltages are wrong. Lack of knowledge 🙄
I
If you see 41V on each lead of R269 and 0.75V on each lead of R267, then you should see about 40V between the two resistors leads that are ostensibly joined near C237. A shorted C237 wouldn't permit 41V to be present at R269. Probe from lead to lead and from lead to board trace to find the problem.
Maybe I'm not measuring correctly. Also find it difficult to understand instructions due to language and some limited skills. I'm going to read the conversation again tomorrow to learn from it and understand it better.
C237 tested / seemed not that bad. 46Uf vloss 2.1 esr 0.82. Nevertheless, the problem of the bias voltage has been resolved after replacement. I'm going to listen to it tomorrow and maybe put it together. Again thanks a lot!
Perhaps in the process of replacing the cap, you repaired an associated solder joint. The PCB trace joins together leads of R267, R269, and C237. The combination of all the measurements suggests this junction was somehow defective.
Enjoy!
  • Thank You
Reactions: Ingy76
