WTB Universal Power Supply Board
Wanted to buy
Hi there, anyone have an extra universal power supply board I can buy? I'm building a firstwatt clone, I'm pretty sure they all use the same board from the diyaudio store, but they're out of stock for the next few months. Thanks!
Hi everyone, I have the same situation as Pestoman: I'm gathering my parts for an Aleph J and the diyaudio store are out of stock of the UPS boards. If anyone has a set of the boards I could purchase I would appreciate it. Thanks, Bill
Hello, I have two designs of power supply pcb's one rated for 400 watt and other rated for 800 watt, if you want to check them see my listing regarding TA3020 and my listing regarding LME49830 or if you need I can send some pictures..
Bill FWIW, when I emailed the store they said 3 to 6 months until they restock. I'll definitely be buying a couple when they are available. Good luck. I think if you know what you're doing more than I do, there's an etsy store called thatcherdiyaudio. It wad recommended to me on the general aleph j thread. He has a psu board that is the closest I've seen to the one they sell at the diyaudio store. But this was my first build, I didn't want to even touch a psu without a specific step by step guide. The layout of the thatcher board seems to be a bit different.
Thanks Pestoman (and others who have commented). I'm in a similar position to you, my preference is the DIY Audio Store boards where I can use the build guide. But I will also look at what you and others are recommending and do a bit of research to see where my confidence zone begins and ends 🙂
Hello,I am the developer of the PSU pcb's so bom and sckematics are provided..
