What is the Best Full Range driver under $70
You are going in circles, and if you look at every possibilities, you will never build anything.
Go with your budget, try something. Listen to it, be happy, and later, try to see where you can come up with something better.
DIYAudio is not trying to get it 100% right from the beginning. It's about the journey into something you like.
Reactions: GM
dave
