AVC, TVC or Stepped Attenuator?
the impedance of tvc or avc is only low at the lowest frequency, it rises as signal frequencies rises...so the thing needed enough mass at the lowest frequency contemplated, say 30hz...
likewise, the voltage levels will also be very low, in the hundred millivolts levels....so impedance may not be such a real problem...
Reactions: rockies914
...an inductive load draws more current at LF than a typical resistive load so the buffer relieves the source component of this loading.
Hmmm... So that's it?
The Intact Audio AVCs I have "come with approximately 140hy's of inductance ,.. The core is 80% nickel..."
How would one figure how much current needs to be sunk into the inductive load at 20Hz?
The buffer's needed because trafos - whether autotrafo or true trafo - work best being driven by a low source impedance.
I think I have that covered. The RIAA preamp has a mu-follower output using a DN2540 as the plate load. While that can't sink more than the 6mA it's set to, it does have low Zout.
Thanks. I'm afraid I'm not familiar with that equation. What is j? What is w? (I know L is inductance.)
160uA? That seems trivial. Even a 12AX7 cathode follower could sink that current into the load, with a Zout of about 1k ohms.
An LM4562 opamp can sink maybe 3mA into the load, which seems like plenty in this situation. No?
j is there to indicate that the current and voltage are 90 degrees out of phase with each other. In math its the square root of minus one. w is my approximation to the Greek letter 'omega' which is the symbol for angular frequency (2*PI*f).
Yes to your other questions - I build AVCs with less inductance than that nickel cored one you mentioned so they draw even more current. I just make sure I have enough current on tap and a low enough driving impedance in the driving circuit, I don't add an extra buffer.
  • Thank You
Reactions: rongon
I wonder if there's a substantial audible difference between a 400hz (military/aviation) variac, and a run of the mill 50/60Hz unit. I know you can use a 400hz unit on 60hz, if you derate it substantially, but we're talking full range audio (hopefully, haha). Fun stuff!
buffering AVC/TVC in front is matter of sources driving that same AVC/TVC
then its Rout is low ....... will you need buffer in front of another stage, not matter of AVC/TVC
ask XRK why buffer is there ...... I'm not familiar with "BTSB"
BTSB is a an op-amp buffer for SE/BAL buffer conversion. I have parts for my sources, but haven't put them together yet.
Salas Ultra FSP phono preamp with a MC cartridge.
AD1862 DAC with Patrick's xen IV (jfet based)
Sony DVD player for spinning discs. Sounds decent.
I received my switches last week.
