Circle cutting jig recommended
Joined 2021
This router jig was very good at making the holes in my new speaker project. Easy to use, not expensive and consistently accurate. I only had to make 8 holes of 2 sizes but they all turned out perfectly.
I have not seen that one before, but most of them are nearly identical. I think that mine is a Jasper jig which gives you the option of setting the jig to one size, going on to another, and then coming back to set the original size exactly.
Reactions: GM
Was just checking out the
“small circle compass “ website . Lot’s of affordable ideas.
Sure could allow me to make more accurate cut’s which can be difficult when you don’t have many tools or a shop to use them in
https://www.aliexpress.com/item/4000535487939.html?spm=a2g0o.store_pc_allProduct.8148356.7.32a4168awAxQba&pdp_npi=2@dis!CAD!C$ 56.33!C$ 31.55!!!!!@21038eda16776753327458598e7908!12000015806488136!sh
Haven't used the one in OP. The item in my attachment is excellent. Its the best jig I have used. It's designed for trim routers, and initially I thought that 1/4" trim router isn't the best plan. Then I used it and wondered why I dint use a trim router for holes all along. Thinking about buying a second trim router with jig mounted and dedicated to holes.
Here I’m looking for a circle jig and my router is nothing short of dangerous. Well it’s not that bad but it’s difficult to use. What I really need are suggestions for a router and a table. What are you guys using?
I recently replaced a crappy circular saw with a new skilsaw and I’m still flabbergasted at how much I enjoy using it. I’m an old guy who has always just made do. Maybe I’m getting past that?
Suggestions please
Best
What trim router’s are you considering?
Interesting,
I do like Makita and will definitely check it out. I have tosay im not a fan of Dewalt. I’m just not used to the location of the reversing switch. Hey I’m old what can I say. Lol
Best
I only occasionally need to make speaker cutouts, so I couldn't really justify buying a circle jig. I made this little gadget at work on my lunch hour, and it's attached to an old 5 Amp B&D router, which is more than enough for the 1/4" end mills I use. Nothing fancy, and you have to set it by hand with a tape, but it gets me by.
