Beyma 15BR400
audio geek how do you work out suitability for sealed ? I use the equation somegave me on here
desired system q ÷ driver qts x driver fs give you your 3db point in a sealed enclosure .
so 0.707 ÷ whatever × whatever
to work out the box required is
q ÷ qts × the result by itself then - 1
then vas devided by that figure
gives you your volume
