Of course you can get Class A in a small chassis. You just don't get much power - or you get a screaming hot chassis. The itty-bitty heat sink on the Schiit Rekkr may be good for a few watt. Maybe 1 Wpc in Class A. But then again, nobody's claiming the Rekkr is Class A. Not that I can tell anyway.
"Exotic, fully discrete, ..." Ooohhh!!! Ahhhh!!! This is Stoddard at his best.
Tom
Tom
An amp modelled on a `hit and miss' agricultural gas engine. What an awesome concept.Many years ago, I tried to introduce water cooling to these physically tiny transient loads we used to test power supplies. By mounting a copper, fluid filled pipe very close to the FETs thermal tab, you could use it right up to SOA limits all day - as long as the water flowed.
But, they didnt like "water" on an electrical test bench (testing voltages in the single-digit range) so they s-canned my idea, put a tiny little HS on the device and added thermal shutdown protection. It was still usable in transient operation; a transient current device that was now only usable transiently...Better score that measurement quick!
The cooler / pumps were a common design for CPU cooling and they were way overkill. To be usable in a HiFi amplifier, fluid flow would have to be of course enabled silently. But if you could do it, the amp could be the size of a mint tin, or the current size of this product but with more WPC, harder bias - whatever this one cannot do because of the HS limitation.
I say if the computer gamers are as enthusiastic to drive a market for these water cooling systems, why not "Us"? If the coffee guys are enthusiastic enough to have a direct cold water line to their espresso machine... I say that because we do not know how much water it would take to cool during a 3 hour listening session. 1 or 10 gallons? It'd be simple to figure out empirically.
Or, maybe mount a Stirling engine driven fan on the heatsink... very steampunky. the ultimate mechanical/thermal governor
Why on earth would you even want A/B on such sensitive drivers?
Class A/B is for weaklingsezzz.
andynor - what don't you like with the performance?
Most class A designs seems to be tied to the "no feedback" etc. paradigm with quite poor clinical performance.
I want a clinical sound 🙂 i.e. no sound... I like the spec and measurements of the Rekkr.
I challenge all the talented designers here to come up with a competitive bid for a small amp... I would if I could... but don't have the skills...
Maybe you could reach those spec with an F5 running on lower voltage and lower bias with more feedback. There is feedback in a lot of the class A designs you can see around here. I don’t know if you have ever heard a properly assembled F5 but it is quite impressive and neutral, or maybe clinical as you said.Most class A designs seems to be tied to the "no feedback" etc. paradigm with quite poor clinical performance.
Tom
From what I've found so far... It's an AB design with a capacitor/diode voltage doubler. Low bias and heat dissipation, with a large-ish music peak ability and good specifications - hence the miniscule heatsink and very limited air-flow.
However, it does have a very short signal path and thick&wide PCB tracks where it counts... something that I appreciate a lot in an amp design.... above anything else - measurements are important, but not at the expense of what I like to see in an amp.
My ACA monoblocks sound nice... but they do run as hot as a smelting furnace.
Sometimes those thick traces effect the measurement in a positive way. Water cooling, I'd bet you could get something like this to work https://www.ebay.com/itm/165841516883 - with a big outboard HS and plumbing.measurements are important, but not at the expense of what I like to see in an amp.
But, they didnt like "water" on an electrical test bench (testing voltages in the single-digit range) ...
The cooler / pumps were a common design for CPU cooling and they were way overkill. ... If the coffee guys are enthusiastic enough to have a direct cold water line to their espresso machine... I say that because we do not know how much water it would take to cool during a 3 hour listening session. 1 or 10 gallons? It'd be simple to figure out empirically.
(1) My current and past expresso machines support direct piping.. that's the easy part. The hard part is the drain. So, for the time being, I use water from a water purifier and a large pitcher.
(2) What kind of coolant do they use in PC liquid cooling pipes? Could a copper pipe be sufficient to carry the heat away from the heat sinks?
(3) How about immersing the heat sinks into a non conductive liquid?
I've thought about using PC cooling designs into a Class A chassis so that it could fit inside cabinets. The coolant could be a bucket of oil, or such, as they use for loads into RF transmitters.
It appears to be pure distilled water with some corrosion inhibitors and colouring. Here's an example: https://www.titanrig.com/xspc-pure-...olant-1-liter-uv-red-03-75-xs-0107-08-on.html
Mineral oil would probably work. It just makes a huge mess if it ever gets out of the pipes.
Tom
Tom
I checked shiit europe.... shipped to my home I estimate it will be corresponding to 262 USD inc. (€ -> skr -> USD)
https://www.firstwatt.com/pdf/art_leaving_class_a_2019_redux.pdfandynor - what don't you like with the performance?
Class D then... vanishingly low distortions. Powered with an SMPS ... then you'll have a full package.
Yeah! That Klunk reminds me of a sound that mains contactors make when a direct online (DOL) AC motor starts. Exactly the same. 🙂
The Gjallarhon were not listed in the European shop on Saturday so I ordered 2 directly from US.I checked shiit europe.... shipped to my home I estimate it will be corresponding to 262 USD inc. (€ -> skr -> USD)
With taxes and delivery they will end up at around 410 euros each to FR, so just slightly less than the EU shop but not enough to bother.
Except that I just checked and if they are now listed in the EU shop, they are still not in stock and/or available for purchase.
TNT, you should look at the ACA Mini, which is really just a mini F5 but running on a single supply and AC coupled front and back. It would run warm in a large metal case.Anyways,,, where is the Diyaudio 5 watt. low distortion, luke warm running class A/B amp? 🙂 equal or better then the Rekkr?
Or Class AB powered by an SMPS.Class D then... vanishingly low distortions. Powered with an SMPS ... then you'll have a full package.
I don't get the fascination with Class A. All you get out of that is a lot of heat. There was a point in time where Class A was a way to get lower distortion. But a well-designed Class AB can achieve the same low distortion without all the excess heat.
Then again, the ACA is not about low distortion. As far as I understand it, it's about getting some amount of low-order harmonic distortion that some find pleasing.
Tom
- A tibute to the ACA & the ACA mini?
