American screws drive me nuts!
I just wonder if they redefined the meter expressed by a fraction of the speed of light, and the value is so close to 1/300000000, why did not they chose that value? The difference would be negligible in everyday life (perhaps not in astronomy, but there are other units used there anyway), and it would be nicer. Easier to remember for sure.
Ha, the six meter long Chrysler Imperial LeBaron dwarfs that.
I have a roadmap to be president ! Give each american a Fiat 500 and a mini fridge ! Global Warming solved ! But of course as a future half president, give me the Chevrolet ! Vice President will be Greta Midget MK I (I miss social media exposition for the moment)...oups I forgott her pun about cars on Twitter !
For the next 4 years, we will put wheels on the mini fridges or cooler compressors in the Fiat 500s ! 🤔
They tried that. The Meter started as one ten-millionth of the shortest distance from the North Pole to the equator passing through Paris. They cut and scratched a stick that long..... then discovered that their distance was in error. Ever since then they really mean "the length of our stick" but express it in ways more precise than two stick-scratches, a microscope, and a good thermometer.
Had the speed of light been a tangible thing when the metric system was established it could have been decided to make it a round number of meters per second. With 200+ years of metric system history it would be chaos to move the actual length of the meter by more than trivial roundoff at the last digit.
Oh, and you'd better not tell any voter of your plan if you want any chance of being elected...a FIAT 500 and mini-fridge ain't gonna cut it.
From Wiki:
"Since 1983, the constant c has been defined in the International System of Units (SI) as exactly 299792458 m/s; this relationship is used to define the metre as exactly the distance that light travels in vacuum in 1⁄299792458 of a second. By using the value of c, as well as an accurate measurement of the second, one can thus establish a standard for the metre."
But if the meter is defined as c x second, then what is the definition of the second? From Wiki:
"Since 1967, the second has been defined as exactly "the duration of 9,192,631,770 periods of the radiation corresponding to the transition between the two hyperfine levels of the ground state of the caesium-133 atom". This length of a second was selected to correspond exactly to the length of the ephemeris second previously defined. Atomic clocks use such a frequency to measure seconds by counting cycles per second at that frequency. Radiation of this kind is one of the most stable and reproducible phenomena of nature. The current generation of atomic clocks is accurate to within one second in a few hundred million years. Since 1967, atomic clocks based on atoms other than caesium-133 have been developed with increased precision by a factor of 100. Therefore a new definition of the second is planned."
Reactions: diyiggy
Reactions: diyiggy
since the gravity constant is not anymore, the second seems to be the last branch to hold. Always wondered if the metrology inside an atomic clock was precise enough due to the manufacturing and infinite variation of the substract inside to fix a precision limit digit limit after the dot ?
Right hand drive leaves your left free while left hand drive leaves your right free assuming you agree that steering is more important than gear changes.
Especially since automatic gearboxes are plentiful but automatic steering not so much.
No, no ...the horseman riding had the reins in their left hand & early warriors had his sword in the right...later it became the gun. For the right hand drive cars, the left is on the steering-wheel, the right out the open window with the weapon of choice....sword, gun, or as now, their cafe-latte thrown in anger.
-----------------------------------------------------------------------------------------------------------------------------------------------------------------Rick...
Oh, sadly there was a similar accident, with huge Human loss, when an Aeroflot plane (fully metric and speaking meters, kilometers, liters, etc.) crashed on Indian airspace with another speaking feet, knots, gallons, etc.
Having worked in the Aerospace business, Aeroflot being all metric is strange. I worked on Boeing 767, 737, Airbus A380, A330 and Comac (China) C919. I didn't see the whole plane, but to my knowledge every fastener on those planes was SAE, certainly all the threads we dealt with. We did velocity in knots or mph or kph, loads in lbs or N, energy in ft-lbs or MJ. My unit conversion app was the most used thing on my phone. Also, all of our test reports used paper as the ultimate archive. The life cycle of the aircraft designs are so long that the computer data types are obsolete before the plane needs a design change. It was interesting working in the lab breaking things, but I'll never miss that industry.
