Selecting Capacitor(s) and Resistor(s)
If you have an old Windows (XP, 7 32bit) PC, then I recommend Glassware Audios tube amp design apps and also check out his kits.
As a tube beginner I found Tube Cad and SE Amp Cad very informative as you can play about with the component value and tube types and view the results.
https://glass-ware.stores.yahoo.net/
https://glass-ware.stores.yahoo.net/adsoffromgla.html
https://glass-ware.stores.yahoo.net/tubjourcomso.html
Very interesting! I appreciate you sharing, thank you. 😀
I happened onto information there is Windows XP Mode in Windows 7, which is what the desktop here is; the XP machine is in storage (and happens to be accessible, was considering getting rid of it). If can get that to happen, can download and be off to the races sooner.
I am also happy as see a plethora of resources for running Windows XP, apparently it is still well loved and used. Have to get her out of storage and see if still does the random blue screen of death (it was a custom build, never worked right, and refused to fix it or comply with the contract to upgrade to the next OS when it came out). Worse case, I am certain I saved my copy of XP. Also, being a bare all aluminium chassis, looks superior to the painted black machines now, wouldn't mind having it sitting out.
I can't get Tubecad's SE amp cad to work on my main windows 10 build, and my motherboard doesnt support virtualisation, unfortunately. However, Tubecad Push-pull amp cad does work natively in 10. I have a thinkstation with a Xeon processor I need to try it on there too.
Adriel, I sent you a private message if you want to take a look regarding some resources.
You build the amp with the OPTs you have on hand and optimise the value by listening.
I have not bought anything yet. Yes, I know a little slow, however, been busy with trying to get this place cleaned (still barely any energy) and get some medical stuff sorted.
In many cases people prefer the sound with different amounts of feedback, depending on what they listen to, how they listen and the design of the amplifier.
A while back, when @kodabmx voiced a reasonable concern about oscillations and the need to know the brand and model of OPT, had the idea of using a potentiometer to adjust the value per the directions. Now wonder if, so long as didn't get into oscillations, this could be adjusted for different music. Probably one of my crazy and over complication ideas.
The reason why you are struggling to get a definitive reply from anyone for this question is that the answer is 'it depends'.
Actually, I am getting a definitive answer now, just there are two and differ. Ha.
Best to pick something straightforward and get on with it.
So the 5,5kΩ OPT that differs from the schematic specification (8kΩ) and OPT supplied (IIRC 5kΩ) would suffice?
Another option: Look out for an old tube reel-to-reel tape recorder or console stereo and harvest the transformers, tubes and hardware, Build just the amp point to point if that is your preferred option. For next to no outlay you get to build something useful, and get comfortable with the fundamentals.
Okay, looking into it.
If you were in Sweden I would have an old Tandberg 74 you could look at (ECL86 SE).
Oh, really? I appreciate the offer! 😀 Hmmm... 🤔
There are lots of different levels of competency in this hobby, and we all just want to help you get started with a concrete build of your own.
I am getting that feeling and most folks here are deep into it.
To be clear, I really do feel the desire to help from most of the folks here.
As can be seen, they contain several resistors, capacitors, and inductors. Those things necessarily affect frequency response and phase response of a signal passing through a transformer.
Which achieves different ratios of resistance.
If you read about Bode Plots, you will find that there are a number of frequency poles and zeros associated with a transformer. Thus when a transformer is inside a feedback loop, the loop has to be frequency compensated considering the particular transformer design in order for the loop to stable and not oscillate.
I didn't find frequency poles in the information previously provided...
Also as I said before, changing R16 would have various effects. The effect we may want to consider first is the effect on loop stability if we don't want to risk making an oscillator. Then we can consider the other things that change when we change a feedback loop.
I am not planning on changing anything until know it works or R16 needs to be because an oscilloscope is showing the curves in the square wave (per previous instruction). There is a Tektronix DPO7254 up on Ebay with a starting bit of $6,50USD closing in six days, maybe that be an option. Honestly, I have no clue what these hertz ratings mean, was simply told to get an oscilloscope.
He wants to know what happens if R16 is changed.
Only in not knowing the OPT. Now the question has changed to if the amplifier is now able to be built knowing the exact OPT used in the L1.
He is inquisitive, and sometimes asks questions that don't have simple answers.
Thank you for the complement. 🙂
I have been concerned asking to many questions and that they are all complex.
If he wants baby food answers he can ask for that. If he wants to chew on a steak instead that's his choice too.
I think more along the lines of grits, fried okra (not easy to do it right), and scrambled eggs (this be a supper, evening, meal). Maybe once have the skill to do this, then move onto Swedish meatballs (which for those that never made them take skill and a good bit of time, with lots of steps). 😛
Adriel, could I recommend a book or two to that might help you? Merlin Blencowe's books have been mentioned already, but to be specific I think the one below could be a good introduction to some of the key concepts and personally I find Merlin's explanations to be clear and easy to follow. This is a preamp book, but many of the fundamental principles are relevant to you.
Designing High-Fidelity Valve Preamps, Merlin Blencowe, ISBN: 0956154530
The following is also very good, and covers power amps, but it has a lot of detail on a lot of areas and so could be overwhelming if you're just starting out.
Valve Amplifiers, Morgan Jones, ISBN: 0080966403
I appreciate taking the time to provide this assistance, thank you! 😀
Not exactly. Frequency response breakpoints occur where the magnitude of a reactance, such as a capacitive reactance, equals the magnitude of a resistance. For example, like in a simple RC low pass filter.
"An example with zero and pole..."
https://en.wikipedia.org/wiki/Bode_plot#An_example_with_zero_and_pole
Maybe search the text for the word 'pole'
There is also a section entitled "Straight-line amplitude plot," which may sometime be described as a 'breakpoint diagram.'
That's something not uncommon to see.
All the above having been said, do you know what the variable 'S' is? If not, you should ask because you will find it comes up a lot in the context we are discussing. Same for the Pi and or Sigma notation, or anything else that isn't clear.
Regarding an oscilloscope, there is a learning curve for that. Its reasonable to start out with an entry level 100MHz or 200MHz, 2-channel scope. For example:
https://www.amazon.com/Siglent-Technologies-SDS1202X-Oscilloscope-Channels/dp/B06XZML6RD/ref=sr_1_4?crid=1Z2U5RW3UAVV1&keywords=oscilloscope+2+channel+200+mhz&qid=1676059572&sprefix=oscilloscope,+2+channel,+200,aps,158&sr=8-4
https://www.amazon.com/Rigol-DS1202Z-Channel-Digital-Oscilloscope/dp/B07XSH2NR2/ref=sr_1_3?crid=1Z2U5RW3UAVV1&keywords=oscilloscope+2+channel+200+mhz&qid=1676059572&sprefix=oscilloscope,+2+channel,+200,aps,158&sr=8-3&ufe=app_do:amzn1.fos.ac2169a1-b668-44b9-8bd0-5ec63b24bcb5
Before you buy one though, you need to understand you will have to learn about probes and how to use them, including how to ground probes, and also learn what all the knobs, buttons, and options do on the scope.
For some info:
I don't know what hardware my Windows 7 has, the XP machine was not only built not only built for the graphics of Vista, also for 3D AutoCAD with one of the best graphics cards available, so maybe it will work.
Sent a letter back.
Bet there is. Like a horizontal lathe or a sewing machine.
Thank you for answering my question. 🙂
How about used?
https://www.ebay.com/itm/1954899554...WE+4Qo=|tkp:Bk9SR8af7unHYQ&LH_ItemCondition=4
https://www.ebay.com/itm/2954937611...2/sO6g=|tkp:Bk9SR8af7unHYQ&LH_ItemCondition=4
https://www.ebay.com/itm/1856771309...GWXhAyve26oJi5EMfjbH8/Vs8=|tkp:Bk9SR6iZl-vHYQ (Interesting it has been re-capped.)
Already looked into it last week. 😉
Thank you for the PDFS! 😀
See how mentally deficient I am as all this pole stuff is just surpassing my understanding. If this is a must to satisfy your need regarding R16 and therefore building the amplifier, then I am in a troubling position.
I don't know what S is, however, if must know it for fishing, then I request to be enlightened. If I remember my elementary mathematics, π is 22/7 or 3,16, though been a long time since have used it. Σ is for total, at least in mathematics.
Read carefully. Win7 will work. Even 64-bit! (Just verified here.)
But this will NOT answer your far-flung questions.
As the great Tom Lehrer taught us:
I am never forget the day I first meet the great Lobachevsky
In one word he told me secret of success in mathematics:
Plagiarize
Plagiarize!
Let no one else's work evade your eyes
Remember why the good Lord made your eyes
So don't shade your eyes
But
plagiarize, plagiarize, plagiarize
Only be sure always to call it please "research"
Who was it who said "Good artists borrow, great artists steal"? Picasso, ahh, Pablito, gets mentioned, but as Dorothy Parker said about anything clever
"If, with the literate, I am
Impelled to try an epigram,
I never seek to take the credit;
We all assume that Oscar said it."
Poles and zeros are dead easy. A Bode plot is just a log-log plot of frequency on the x-axis and magnitude (amplitude, could be volts or current or sound pressure or whatever you're measuring) on the y-axis, paired with another plot with the same log frequency x-axis and a linear scale phase angle y-axis. On either of these, when the curve tilts downwards (but not necessarily down), left to right, that's called a pole. When the curve tilts upwards (but not necessarily up) that's a zero. Dead simple.
All good fortune,
Chris
Reactions: Adriel
@Chris Hornbeck A bone of contention on recent posts has been whether knowing that (bode plots etc) is a prerequisite for getting ones hands dirty with a real project. Much of the risk of a failed project is mitigated by standing on the shoulders of giants, and copying an existing design, or taking it to the next level and building on a PCB with known and evaluated OPTs.
What advice would you have for someone who wants to build a tube amplifier, around 10W per channel? What are your views on doing it point to point the first time? Are monoblocks so much better than a stereo amplifier?
Reactions: Adriel
