TPA3116 Upgrades
I put the bootstrap snubbers from the input side of the inductors to the ground plane underneath. Thanks again for the suggestions fellas! The amp looks much less silly now.
I'd like to do the snubber mod on my board too. Have some Wima 0.1uf caps lying around. Will that suffice?
With the original coils, it's hard to see where the input side of the inductors are. From your pic, am I correct to say they are the large solder pads next to both edges of the pcb?
Hello Bernie. The snubber mod specifically calls for a 330pf 50v capacitor and a 10ohm 5% 1/4W resistor. I used these caps and resistors. I am sure any capacitors and resistor of those values will work, does not have to be expensive. Maybe avoid wire wound resistors.
Yes, the way I did it the 330pf cap will go from the outer solder pads at the edge of the board, to the 10ohm resistor, and then to ground. There are many ground points, I just scraped off the mask underneath the board. As irribeo suggested, keep the leads as short as possible.
Reactions: Syd_A
hi guys new guy here from the UK
im currently looking at getting a tpa3116d2 from amazon
https://www.amazon.co.uk/gp/product...act_title_2?ie=UTF8&psc=1&smid=A1XTJ6FZJZ40TR
i was wondering if the following power supply would be suitable?
https://www.amazon.co.uk/voltage-tr...465126765&sr=1-82&keywords=24v+150w+supply+dc
any help would be appreciated
cheers
Tony
Best read the data sheet for the device they are using.
http://www.ti.com/lit/ds/symlink/tpa3116d2.pdf
Power output will vary with speaker impedance.
The power supply you have chosen has a high enough current to run this amp.
There are various opinions/observations of these types of amps throughout a few of the Class D threads...best to read as much as you can.
I have not heard or used any of them so I have no opinion of them.
Happy hunting.
Hi, I have 2 of these red dual chip boards, and I am using them as a more power efficient amplifier, instead of my big Onkyo.
Sound is "OK". I would very much like to improve the sound as much as technically possible.
There's a hiss. I read somewhere in here, that I need to change the potentiometers. So I ordered 2 Alpha 10K logarithmic potmeters.
Can anyone recommend the best ones to replace the 4 power caps?
AND 4
inductors.
I'm running 8 ohms floor standing speakers.
I saw a guy in Serbia on google images, that did the bootstrap mod differently than one of you guys recommend. I added pictures.
Picture 1 is MY setup (x2 ofcourse). Pic2 and 3 is the serbian snubber mod.
OK. I ruined one of my boards today. First time removing a potentiometer, left me with 2 ruined "soldering spots" on the PCB. But eh, these boards are so cheap, and for me it is practice. Just have to wait for a new one, which sucks.
But I tried ordering a different one this time. Also a dual chip board. 2.0 apparently. Don't know what it is next revision of... But it looks like it already has a snubber circuit??
I will also try to repair that board. Will solder 10K resistors in from point to point. But for now, I will wait for the new board. I had an SMSL 36 to substitute for now.
Will be looking into the Sanwu pbtl boards. I really like the sound of my SMSL and that has 3118.
I soldered a 10K potentiometer on the other board. Still a pretty audible hiss. Must be bad layout. Went ahead and ordered 4 pieces of Sanwu 3118 pbtl boards. Need to figure out some volume control. I like those cheap pga digital volume boards but they run AC and have input switching. 2 things I do not want..
Hi everyone,
Totally new to this hobby, bought 2 of these boards XH-M190s and one came broken with a capacitor missing/knocked off . Does anyone have any idea what rating this ceramic capacitor has, C33 placement. Checked with a DMM and the it loops to nothing adjacent C9 ceramic is 3.6 uf.
22pF, best remove c33 on the other board too and also mount 22pF (measure footprint before ordering "massive" or "miniscule" replacement part 🙂
Function is to filter the synch between master and slave, the 1nF datasheet value doesn't work because it filters the frequency the synch works at. EVM values are 4k7-47pF and those do work, so I would think your r13 value gives 22pF to function like the EVM.
