I have got a Chinese PCB board and its called a super regulator by Jung, not sure if it is one of W.Jung's designs but it works quite well, I tried it with a NOS DAC chip, not a but result but it sounds very forceful, a bit too much of a good thing I would say.
I have drawn the schematics of it and it would be great if the design can be improved if can to be improved obviously 🙂.
...please have a look at it and add your comments.
best regards
K
best regards
K
Why buy unauthorised copies when you can get the genuine from DIY store, where you also get support ?
Patrick
Patrick
An un-authorised copy of an un-authorised copy ;-)
A Chinese whispers version of a whisper-quiet regulator?
Happy New Year of the Rabbit!
yes, correct! I have got some of the original Jung/Didden boards and can't get them working at 5vdc at all, and the poor website that explains how to use it is so bad.
so many links to some old explanations and links to upgraded versions and links of links explaining how to set it to 5vdc, and every scenario is different!, and I got lost, and bought a Chinese version that has the pot, and it's easy to set the output voltage,
probably easier job to improve the Chinese Mr. Jung than figure out how to use the real deal thing.
I usually doubth about phrases and words like "super regulator", "ultimate fidelity", "the very best of...", "ultra low distortion...". All crap generally.
Hi Osvaldo, This is not a Literature forum in case you haven't noticed, and not many people in here are interested in what kind of phrases you like or don't 🙂
Thus the title of your thread is self contradictory. How one can/want improve a "Super Regulator"? Either it is no more upgradeable or it isn't the plus ultra. Spelling remains important for proper communication.
dear Osvaldo, don't overthink the title too much!. it's just the Chinese name of this regulator as it appears on aliexpress, but if this is super or uber or ultra i don't know that's why I'm here to ask that question.
I had the same boards a few years back, used them in two electronic crossovers, 3 way, they performed okay, I never really tested them.
If you have some equipment you should measure noise at different loads, I believe a oscilloscope, or even better a soundcard could provide answers
Did you read the article posted with the kit at diyaudiostore.com? What is unclear?yes, correct! I have got some of the original Jung/Didden boards and can't get them working at 5vdc at all, and the poor website that explains how to use it is so bad.
Jan
This?Did you read the article posted with the kit at diyaudiostore.com?
https://www.linearaudio.net/linearaudio.nl/images/pdf/superreg_article(1).pdf
or: https://www.linearaudio.net/linearaudio.nl/images/pdf/superreg_article.pdf
Both 404
hi< Yes I did, and I got it working at 5vdc, thanx,Did you read the article posted with the kit at diyaudiostore.com? What is unclear?
Jan
- Power Supplies
- Improving the Chinese Jung super-regulator
