Hi everybody,
I have two Fidelity Research FR-64s tonearms. They both work perfectly.
I noticed, however, that they have the different endpoints of the horizontal moving.
One of the arms can be placed directly above the TT spindle, just this position is the endpoint of its horizontally
movement.
My other FR-64s can be horizontally moved through the above mentioned endpoint a little bit further (apr. 20 degrees after the reaching the TT spindle).
The same situation by the moving right: the first arm can be horizontally moved just to the rest area, my other Fr-64s can be moved outward after the reaching the rest area a little bit further.
Is with this FR-64s something wrong and the arm must be repaired or serviced?
Thank you for any advice.
Paul
movement.
Paul
Tnank you Dave...🙂. If I had only one FR-64s , I could never notice the strange difference between the horizontal movement of my tonearms.
It has been over 40 years since i have seen an FR64 in real life. Really well done arm.
Since you never play the label i would not worry about it. Do the 2 arms sound the same?
dave
dave
Yes, they do.Do the 2 arms sound the same?
