Hello, I need to buy one ak4499EX chip to replace the broken one from my DAC. There is any chance to find it somewhere ?
If it is broken maybe it is wise not to replace it as the new one might break down too. Or didn't it break down by itself just like that?
Hi ... is it the AK4499EQ you need to find (the "integrated version") or the new AK4499EX - which is the "standalone" version?
Cheers, Jesper
Cheers, Jesper
It's my fault. I accidentally touched the VREF pin with 12v.If it is broken maybe it is wise not to replace it as the new one might break down too. Or didn't it break down by itself just like that?
Hi again - would be interesting if it were available from Arrow, however, when I do a search on arrow's webpages it seems that I need to buy at least 250 pcs ...
Any chance you have a link to a one pcs purchase option from Arrow?
Cheers, Jesper
Cheers, Jesper
Wooowwww ! Yesterday I bought by the piece, two pieces with 59.60 EUR. It was aprox. 1650 pieces in stock. Today are only 1500. They sell this chip very quickly but it can not be used without AK4191.Hi again - would be interesting if it were available from Arrow, however, when I do a search on arrow's webpages it seems that I need to buy at least 250 pcs ...
Cheers, Jesper
I'll go at the laptop service to change it. The most probably they will use an infrared de/soldering reball station.
Eventually AK4499EXEQ should be available at Digikey. For now the only AK4499EX product that can be ordered is an evaluation board. OTOH if you need the original AK4499EQ, maybe I could help with that. Have a couple of them on boards which I don't see a need for in the long run.
Now is on Aliexpress 😃
https://m.aliexpress.com/item/10050...a2g0n.ppclist.product.0&gatewayAdapt=Pc2Msite
- Digital Line Level
- I need to buy AK4499EXeq
