TL081H
"outstanding value for cost-sensitive applications"
Reading between lines, the hiss is not as low as other cheap parts, and the specs imply a good dose of 1/f hiss.
Until I need a LOT more opamps, this does not call out to me.
"integrated EMI and RF filters" are nice features that other opamps sometimes lack. Otherwise nothing really special except ultra low power consumption and not a threat to OPA1641/42/44 in audio applications it seems.
Probably the most recent/revised workhorse low cost opamp for a broad range of industrial applications.
TL series are wonderful, but I actually prefeer CMOS TLC series, faster and lower waste of energy mainly in battery operated rigs.
20v/us is more than enough for audio,+-2.25v.... +-20v supply says it's not working only for battery operated devices, 940uA quiescent current keeps your battery alive ...I'm not gonna post all the datasheet of tl071h-tl081h here just because....
It is purely a choice if someone wants to have some 20 bucks op amps to sell in 2030 for a discount in the swap meet section ...
Do these also suffer from the inverting output / rail clamp when operating near rail Voltage like the elder ones ?
The old TI TL084 data sheet specified a common mode input range that you had to stay 4 volts away from both the rails.
This is a lot of voltage and many designer got caught on this when using low voltage rails like +5V/-5V.
The new TL084H data sheet shows the common mode input range extends to the positive rail and down to only 1.5 volts above the negative rail.
A very big improvement.
Unfortunately TI has stated they will NOT release undated spice models for the "H" version making simulation of any of the "H" advantages not currently possible.
Pity, I stopped designing without spice in the 1980s.
