I had put my five year old rabbit ears on my amplifier and seems it's well done. Started shopping for a new TV antenna, reading there are ones that claim to have 10X the signal range, going to hundreds of miles. As little as l like broadcast TV, it's still nice to have - to keep my better half happy I need to pay for PBS.
More important is keeping RFI to a minimum... and don't even know if the frequency used now makes a difference. Have plenty of tubes in various stages. Many alligator clip pairs to keep looking for most quiet background.
All TV antennae have amps built in?
Cheers!
Cheers!
No. Many VHF installations didn't use amplifiers. Since then, many UHF installations have separate masthead amplifiers with power fed along the cable.All TV antennae have amps built in?
The question becomes -- how far are you from the transmitting antenna -- most of the terrestrial TV broadcasting is now well higher than the 3 meter band where it was previously located so a simple UHF antenna bought at Best Buy will do the trick.
For FM broadcast, 88-108MHz -- a yagi antenna is directional and will give great results...you can also DIY a low noise amplifier, or buy one from the usual suspects.
The 10X gain may be fantaciuos. As long as the amplifier amplfies signal and noise; and adds noise, not always is better solution. Yagis are good as is said above.
https://www.tvfool.com/index.php?option=com_content&task=view&id=66&Itemid=1
I haven't checked this site for years but it tells you which TV stations to expect in your area, and what band they're on.
