First watt F7 restoration
Mods please remove this if it's in the wrong place. I am restoring an f7 for a friend. The power supply capacitors need replacing. Is it ok to ask how to set the bias to factory specs.
Agreed with what ZM wrote. The F7 schematics hasn't been released so you should discuss this in private.
I'm also suprised by the need to replace the PS caps given the F7 isn't that old. I wonder if the amp might have been used without adequate ventilation.
Reactions: chermann
Mr Pass I don't know how to tell you this but your amp is no longer as it left the factory. It's a mess. It has a larger power trans fitted, I Am trying to source the original trans and return to as original as possible. I fear they have messed with the bias when they changed the trans. I don't even want to turn it on until I know what they should be set too. Maybe the capacitance is ok. It's in far north queensland with very high temperatures. I Am trying to contact his tech to find out why he changed the trans and hopefully get the original trans back.
Mr Pass I have made further inquiries the power trans is original. He was referring to the additional bank of capacitance added. So my job is a lot easier. Only the signal wiring will needs replacing. There is one power resistor that's been changed so the bias maybe off still. He said the resistor was running too hot but why? The additional capacitance probably ruined everything.
Maybe post pictures of the inside so the extent of the change will be understood?
I really can't show the inside. Unless I Am authorised to do so. No user serviceable parts! It's just so far away from california and in such poor shape. He actually gave it to me for parts to build a diy pass amp. I just want to fix it for him. Especially now that I know the pt is original and caps might be ok. I'm only 2 resistors from original. They are nickel ww probably inductive between the output devices.
That was nice of him. I think if you are concerned about not showing the circuit, you can put pieces of paper over the amplifier boards. That is the important part.
If you decide to take pics, maybe circle in MS paint or something the areas of concern.
Take some pics. The extra cap bank may not be a terrible thing if properly implemented. Although it probably doesn't need it.
I’d take this dialogue directly with Papa through e-mail. His address is readily available publically.
WW does not sound like Papa’s recipe for an OS.
Yes, restore to original state. These are rare seldom output devices and a cool circuit.
The RCA and binding posts in post #1 also don't look like what I have seen on other Firstwatt amps.
The one binding post clearly visible looks corroded to me. 🙁
6moons has a review of a pilot run F7 with a lot of photos. It might not be exactly the same as what you have but
should give you an idea of what an original would look like.
Good luck with your restoration.
Depending on what the mods are, you may not have to worry about returning it to original per se. Extra capacitance isn't going to hurt anything. A larger transformer is not going to hurt anything...
Silver signal wiring is not going to hurt anything either. I suppose if you're restoring it as a conservationalist, then I could see the appeal of putting in the effort. Otherwise...
