This scheme should also probably work. Remember, that last capacitor's impedance dominates Zo now.
It's lytic, tomorrow I can change for film or I get off the RC?
The preamp is finished just need a power on/off switch to delay 1 or 2 minutes the B+
That RC branching is a detail... you will replace caps to see, also test with and without branches and you will decide. Not a problem for initial test.
Huge chassis!Work in progress.
You can reduce further with a couple RC stages at the feed to the LM317s, but 2mV is likely to be inaudible with the indirect heated cathode. Should work well.
Also able to burn some heat on RC filters before LM317 in situations where DCin is high and sink is small.You can reduce further with a couple RC stages at the feed to the LM317s, but 2mV is likely to be inaudible with the indirect heated cathode. Should work well.
- Tubes / Valves
- 6V6 line preamp
