FS: 12" Acoustic Elegance Lambda Woofer Driver PB12 with Copper Faraday Rings - 150$ ( Single Woofer )
Woofer:
Acoustic Elegance Lambda Driver PB12 with Copper Faraday Rings in excellent shape.
The copper faraday decreases inductance and as a result distortion is decreased.
It has Xmax of about 15.5mm.
Parameters for the PB12:
Fs: 21hz
Qms: 4.2
Vas: 160L
Cms: .4mm/N
Mms: 143G
Rms: 4.5kg/s
Xmax: 15.5mm
Sd: 530sqcm
Qes: .32
Re: 3.5
Le: .3
Z: 4ohm
Pe: 500W
Qts: .3
1W SPL: 89dB
PB12 is the predecessor of SBP12.
SBP12 Highlights: (from manufacturer's website):
The SBP Series are also the ultimate option for automotive infinite baffle use. They have a larger motor then the IB-AU Series for more efficiency in the upper bass region where there is very little cabin gain. This allows them to integrate and work extremely well with the cabin gain in your vehicle. You will not find a lower distortion woofer for Automotive Infinite Baffle applications.
https://aespeakers.com/shop/sbp/sbp12/
http://www.aespeakers.com/Lambda001-1.php
Bought directly from:
Acoustic Elegance John E. Janowitz
http://www.aespeakers.com 1825 Mills St.
Phone: 920-469-9198 Green Bay, WI 54302
Mobile: 920-217-0625 Fax: 775-258-1406
Woofer:
Fs: 21hz
Qms: 4.2
Vas: 160L
Cms: .4mm/N
Mms: 143G
Rms: 4.5kg/s
Xmax: 15.5mm
Sd: 530sqcm
Qes: .32
Re: 3.5
Le: .3
Z: 4ohm
Pe: 500W
Qts: .3
1W SPL: 89dB
- Lambda Motor with Full Copper Faraday Sleeve (FCFS)
- Extremely low and linear inductance
- Wide bandwidth and detailed midbass
- High Xmax with clean suspension travel
- High Efficiency upper/midbass
- Designed for sealed box applications
- Also ideal for Automotive Infinite Baffle use
Yes single woofer and ONE is available. I used it as a Sub. Thank you for your interest.This is a single woofer, one available?
I cannot figure out how to edit the title of the post. Is this a new feature or restriction of some sort? Other forums allow easy editing of the Thread Title along with the post. otherwise the Title price still stays high and does not reflect me lowering the price.
Thanks for your assistance.
Hello! How old is the driver? What sort of smallest sealed enclosure it can work with? for 50hz upwards..
You need to message a moderator. Posts are locked from editing after 30 minutes, IIRC.I cannot figure out how to edit the title of the post. Is this a new feature or restriction of some sort? Other forums allow easy editing of the Thread Title along with the post. otherwise the Title price still stays high and does not reflect me lowering the price.
Also, I feel it's a bit disingenuous to include so much marketing spiel for a driver that is not what you are selling.
