Beyma 12BR70. Min ported enclosure needs
Ran the numbers thru Winisd & I got this...internal volume, 288.3 liters, a tuned frequency (fb) of 28.1 hertz, choosing a round port of 200 mm size, it came out at 260mm long, velocity was fine. Response is at -2.99 Db @ 25.3 hertz....
All in all just fine...The efficiency bandwidth product came in at 62.5...a little "all purpose" for ported or sealed, but sims out just fine...let alone hot-rodding the tuning for a deeper response.
--------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Rick...
Many thx
ill build a 80l cabinet!
80 Liters sealed? , you're hampering the performance capabilities thus...an F3 at 50.88 hertz along with a Qtc of 0.83 ... a bit on the "flabby bass sound", critically underdamped.
80l ported?
if sealed, whats the min size for best performance?
Hello !
Vol min No serie resistance
Vol max serie resistance = 0.6 ohms
Closed :
Vol : 43 L f-3db : 70 hz SPL max 93.4db R series 0 ohms
Vol : 52.8L f-3db : 64.4 SPL max 93.1db R series 0.6 ohms
Ported :
Vol : 84.05 L f-3db : 43.6 hz SPL max 93.4 db Port D : 100mm Port L 118.5mm Port F 39.32hz R series 0 ohms
Vol : 110.15 L f-3db : 38.3hz SPL max 93.2 db Port D : 100mm Port L 93.7mm Port F 36.54hz R series 0.6 ohms
Hope this help !
