Cartridge load of MC and MM RIAA amplifier
If you want MM cart sounding as clear as MC, I recommend 150 k/ 25 pF load instead of "standard" 47 k/250 pF - [ https://www.patreon.com/posts/70415214 ]
Please, how can you achieve a 25pF load on a cartridge if the cable from tonearm to preamp has roughly 100pF to 200pF capacitance, all by itself?
I measured the tonearm's internal cabling capacitance (C measured from the headshell wires to the tonearm's output connector) and got 30pF.
How does one achieve a zero capacitance tonearm to preamp cable?
Mine won't fit
You get in the right ballpark by putting the preamplifier inside the turntable.
Yes, that's what I thought.
That means this will be a high budget, customization project.
Most MM carts are designed for the budget-conscious. Most bang for the buck.
I'm left wondering if the effort of redesigning your turntable to allow mounting of the phono preamp inside the turntable's plinth is worth it for optimizing a $200 cartridge like AT-VM95SH, or a vintage classic like Stanton 681EEE. How would you go about mounting the preamp in an SL1200? I guess it would have to be an opamp based PCB running on +/-15VDC @ roughly 10mA. Would it need its own power transformer? Or is the power transformer in the SL1200 capable of the extra load?
Budget minded? V15III gives some mc units a run for the money.
Slightly disagree with you, unless it´s a horribly cheap MC.
My Shure, although the V15-IV MR (less than 100 hours) is still outperformed even by a AT-PTG/II, and when I move to
WTL-Kauri, Ortofon Jubilee or Kiseki Blackheart, we are talking a totally different league.
That said, I still prefers the Shure or my Goldring 920-IGC with new shibata stylus on some music like old Moody Blues etc.,
but always have one turntable permanently mounted with a MC for newer recordings, especially Jazz 😉
I've improved reproduction with my Goldring 1012GX (more airy and clear highs) by shortening the cable as much as possible so the load is 120pF total (inc. tonearm wiring) with 56k.
Make simple analysis with equivalent LRC circuit in LTSpice to get idea what happens when C and R change
Reactions: Boydk
