Schiit Freya 6SN7 Tubes?
6SN7 - Schiit Freya... I have a Schiit Freya (not +)...I'd like to do some tube rolling. I bought it second hand, with 6SN7EH Electro Harmonics and Tung Sol 6SN7GTB SOL tubes. Sounds great, but I want to see if different tubes will change the sound in some positive way. What would you folks suggest I might want to try. Looking to spend around $50 a tube......Thanks
I'm not sure about your particular application, but GE 6SN7GTA with grey plates and side getter are excellent sounding tubes. Vacuum Tube Valley #11 listening tests stated "GE 6SN7GTA ( 1953). A tube with nice imaging and a romantic, satisfying sound. In addition, it had powerful bass and detailed, accurate mids. Rating 94" One of my favorites.
Tube Rolling! Schiit Freya... OMG! Can't believe the difference these GE 6SN7GTB tubes made. I used to question all this tube rolling stuff...No longer! I bought new Tung-Sol 6SN7GTB and Electro Harmonics 6SN7, This is what the Freya had when I bought it a couple years ago, second hand. I figured the tubes might be old and need replacement.....And I found a set of matched, NOS General Electric 6SN7GTB for a reasonable price. Put the GE tubes in the right slots and the new TS in the left.....Amazing difference. Much deeper and tighter bass....but the big improvement is vocal. Much more out front and better definition. More than just a subtle improvement....Will be mixing and matching to see what other combinations bring.
Superfluous...All you need is ears....And what sounds good to YOU.....😉
And I have a bridge for sale...
Reactions: Osvaldo de Banfield
I'm glad to hear that you like the GEs. The GE 6SN7GTA is significantly better than the GTB. The top rated Sylvania 6SN7W is even better sounding than the GTA, but rare.
Soviet era 6N8S can sound very good, but you need to buy a bunch and sort through them in my experience. They don't have the "romantic" sound of the GE, and are more neutral in tonality.
Osvaldo, the VTV article does have some of the info on pp6-7 of Issue #11. From page 9, the listening test "was conducted in the VTV listening studio with the following equipment: VTV Octal Line Stage, Pilot SA232 basic EL84 stereo amp (rebuilt), B&W DMl 10 speakers, Sony CD player and Monster Cable speaker wire." The VTV octal line stage is described on page 10. See the Vacuum Tube Valley #11 link above.
Over the years, I have found VTV listening tests to be very helpful. Vacuum Tube Valley
Some classical music is described as romantic. Describing sound is inherently metaphorical.
One thing to mention with used 6SN7s, even new ones can have a lot of getter deposited on the top glass, and it is no indication of the condition.
