Capacitor ratings for LM386 based guitar amp
I'm building a little LM386 based guitar amplifier, and I have some 16v rated capacitors I want to use in a couple locations. I'm running this particular amplifier at 18v (two 9v in series), and using an LM386-4. I'm not great understanding/analyzing at these types of circuits, so I was wondering if anyone could possibly help me determine whether 16v rated caps would be acceptable in the highlighted positions, or if I risk blowing them. I know I can simply get higher rated caps, but at this point I really want to understand this circuit better. Thanks in advance!
Edit: I'm currently using a 4 ohm speaker, but sometimes will plug it into up to 32 ohm speakers.
Elecyrolytics are chemical elements, like batteries. So need a proper voltage value for performing well. Mylar, poliester and the like are mechanical, they have no wet electrolyte to do its job.
Do you imagine a 6V charger with a 12V battery? Or a 24V charger over a 12V batt?. Surely no.
Reactions: NanoFarad
The cap on pin 6 is full supply voltage, use >25V.
All the others are half supply, 16V cap is fine.
Old or cheap electrolytics will "decay" if used far below forming voltage. I have not seen this problem in a long time. Do it now; then if it ever makes trouble you will know how to specify and install a new cap.
Reactions: Piny
Thanks for this! Do you think 25v is not sufficient for the pin 6 cap? Or are you just suggesting at least 25 v?
Also, is it simple to point out why the other caps can be at 16v? E.g., which part of the LM386 schematic is defining the lower voltage at Vout?
