Decent chip for about 10W Pout
You intend to build from new or use the existing supply?
And why is it that you want to change away from a competent chip amp?
That said, 12-0-12, 3A is a perfectly good rating for a transformer, and here we get populated 2.1 amp boards, with heat sink and all, starting about $2.50.
4.1, 5.1 and 7.1 options are also sold.
Takes about an hour to install, you need to add transformer (board comes with AC input), and pots for bass, treble, volume, and also selector for input etc.
The cheap boards all use copied chip amps, and they sound good, particularly if not driven hard.
Better ones are also available, and I for one se no point in obtaining a genuine TI 1875 for $7 (including shipping, for one chip), and the rest of the parts, and fitting it all on a PCB, which again is to be ordered, with all the resistors, capacitors etc.
Too much work.
I use Philips sets found in the flea market, $2 each, with mostly Japanese chips and caps inside.
Matsushita, Toshiba and Mitsubishi chips, Rubycon, Nichicon and Philips caps, Philips pots...what more can you need?
Its purely the frequency response at the top end I find lacking. If you say they are similar I had better check other components first, like the speakers.
P.S.
I realise this is hijacking Tubes4e4 thread, so sorry Tubes4e4 I will start a new thread.
Is there any of the LM1875 boards/kits on the net that is OK to buy?
+/- power please...
HERE
€ 1,85 / lot (2 Pieces)
TI LM1875 is about 4 Euros here, with further price breaks for bulk purchases at Mouser India.
Chinese ones are 0.20 Euro retail here, same as 2030A made in China.
Profusion has a bulk price on UTC 2050A, which is about 60% of the small quantity price. About 1 Euro, IIRC, please check.
The UTC chip is legally licensed from ST.
Ask ST, UTC, or Profusion.
I did read about it somewhere, forgot.
Bear in mind that UTC are using the TDA series numbers, which is sort of used by ST alone (maybe Philips as well), and their products are sold in Europe, for many years, without any objection from ST.
In any case, Europe is known for stringent enforcement against copies, so if sellers in UK and Germany are active, they are not likely to be fake chips, some authority must have been provided.
I believe that no license is required to manufacture TDA2050 because patents have expired a long time ago, and ST listed this chip as obsolete in 2011 already. It is a 30+ years old IC. The 2022 UTC company presentation lists several old wokhorses from TI, ST, NXP and the equivalent parts from UTC. It is unlikely that the silicon manufacturing is done the same way, or that a license of any kind has been negotiated with the original manufacturer.
1875 is also a old product, patents are expired, anyone can produce it as they like, without license. The ordering number for the UTC part is different from the TI part to further avoid any issue: the TI part is LM1875T while the UTC part is LM1875L or LM1875G ,but they add some extra characters ending with a T on the full ordering number. This is common practice for old semiconductors and does not mean that the copy is worse than the original. It might even be better on some parameters, although unlikely. It only means that it is a different part and it is best to do a revalidation if there is a component change request. A new lab test is mandatory if the part has been listed as safety critical. This does explain why some ancient parts are still manufactured by the original vendor despite cheaper competition.
Reactions: NanoFarad
PCAN
You got my point ,
anyone could make an 2030/2040/2050 but that should not imply they will be identical with the original ST TDA2030/2040/2050.
But, when I was very young, RFT was producing electronic components and electronics in Germany(East Germany), they were making a2030V/H chips 30+ years ago.
I said UTC 2050 is similar, and cheaper.
Also, in post# 20, I did say I use flea market amps.
And that there is no point in spending more than $20 to build a 1875 stereo amp, when ready boards are available.
Class D and discrete options are available as well.
Adason has one piece available for $40, if you are so inclined.
NanoFarad / Nirupam, please tell us what test equipment you use to draw the sonic conclusions you claim.
For 10W, Philips used uPC1238 from NEC in older Powerhouse series, TDA2030 is direct substitute if that chip is to be replaced.
Check the data sheets, at 10W output, no difference exists between (original) 1875, 2030 and 2050.
Also, the UTC part is said to be of good quality, so why not?
And for one kit costing $40 at most, we have spent a lot of time over it.
