ADS PQ10 Power Supply Problems
Seems like my PQ10's power supply is broken. Positive rail is moving around 12v and the negative at around -2.5v.
I've never had a need to understand how a car amplifier's PS works, so I took the opportunity to do some reading. Pretty fascinating.
Nothing looks burned out. Nothing looks abused.
I really don't understand the circuit to turn Q801-4 on and off. I don't understand why the circuit on Q801/2 Base is so much different than Q803/4, I thought they'd be the same. (Schematic attached.)
Here are some measurements using 12.1vdc power to the amp:
Q801-4 (all four measure the same)
B=13.1v (erratic) And wouldn't C806 block the dc to the base on Q803 and 4?
C=0v
E=12.1v
Each Base measures around 30 hertz (erratic). I thought this would be well out of the audible range, like 50-100 kHz.
I don't measure any AC on the rectifier diodes (CR807 and CR808). I get -2.7vdc (erratic) out of CR807, and 12vdc (erratic) out of CR808. I also get 2.4vdc to ground on each rectifier on what I expect is the AC connections from the transformer.
I'll check around for a local repair shop, but thought I'd throw it out here first.
BTW, all measurements with a multimeter, no oscilloscope.
Thanks,
Dan
What is the DC voltage on all terminals of IC602?
Copy and paste the following list and fill in the blanks. If there is no blank space after the colon, add one between the colon and the numbers you enter. It makes it much easier to read.
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
I don't think this is going to be good news. Multimeter set to 20v range and Ground In as reference,
Pin 1: varies around 0.8v - 3.85v, seems to mostly read 2.35v
Pin 2: varies around 0.8v - 3.85v, seems to mostly read 2.35v
Pin 3: varies around 0.8v - 3.85v, seems to mostly read 2.35v
Pin 4: varies around 0.8v - 3.85v, seems to mostly read 2.35v
Pin 5: varies around 0.8v - 3.85v, seems to mostly read 2.35v
Pin 6: varies around 9v - 13v
Pin 7: varies around 0.8v - 3.85v, seems to mostly read 2.35v
Pin 8: varies around 3v - 7v
The pins with "varies around 0.8v - 3.85v, seems to mostly read 2.35v" read exactly like the outer pins of CR807 and CR808.
You have to use the secondary ground. The secondary ground is the triangle ground symbol. Any of the non-bridging speaker terminals will be the secondary ground. Pins 2 and 3 should be directly connected to the secondary ground, according to the diagram.
Well, that makes a difference, thanks!
Pin 1: -0.045v
Pin 2: 0v
Pin 3: 0v
Pin 4: 0v
Pin 5: 0v
Pin 6: varies from 9.5v to 10.8v
Pin 7: 0.038
Pin 8: varies from 3.16v to 3.25v
You're here for help, not because you know everything. Post whatever questions you have if you decide to continue.
I can see discoloration on the third transistor from the left. That is channel 3 with the dc on the output. And on the rail with the low negative voltage.
The washer is loose, but the screw is on tight. Maybe bottomed out?
I had the board out and maybe I didn't get that one tied down tight enough and it got hot?
If blown, could it shut down the amp?
When it went, the amp shut down, then came on and shut down a couple times. On my second trip in the car, so not right away.
And there is no continuity across any output transistor or power supply transistor across B, C, or E.
Re-reading a previous post... OL on all leg combinations on ohms seems virtually impossible. What does your meter read, on ohms, if you hold the tips of the probes together?
When set on 200 ohms and leads held together I get 0.1 ohms. When the leads are not toughing, I get OL.
But when I measure between the legs, it will initially reads 60-90 ohms, then resets to OL. That is why I said there was no continuity.
