SLOB design
Are there any drawings of 4x12' slobs out there? I want to build slob boxes that you know work.
Attaches principle sketch.
Does anyone know anything about calculating these?
A clear sketch showing exactly what you have in mind may help.
However, my searches reveal much discussion on SLOBs, but little on methods of calculation. All I can find is this:
"The general recommended slot area is 1/4-1/3 Sd for drivers with Xmax < 5 mm, and no less than 1/3 Sd for drivers with Xmax = 5 mm and more. Rear slot opening should be 1-1/2 Sd."
(Sd = effective area of cone, in square metres; Xmax = maximum distance a speaker cone can travel without distorting, in millimetres)
That means nothing to me, but it may to you since you are a SLOB enthusiast! 🙂
