any schematic of regulated solid state psu for EL84 SE that sound good?
I cannot imagine why anyone would want to use a regulated solid-state power supply with tube power components. The beauty of tube sound is at least partially due to the sag of an unregulated tube supply.
Some just want to listen to the music, as unmutilated as possible.
Others use their amps as musical instruments or effect boxes.
It's all about personal preference.
Jan
one possible solution
two channel. diode on board
Walter
Reactions: Wik
Maybe for a guitar amp in push-pull. For an SE amp quiet is the main concern. A class A SE amplifier doesn't have any appreciable sag unless you do something really weird or wrong.
It doesn't sag that much, but it produces a signal related ripple at B+ due to the source follower Zout.
That ripple, which is a distorted version of the signal, is directly in series with the output signal.
There is a reason why most SE amps sound different from each other.
Jan
Jan
True.
SE Tube amps are not exactly the pinnacle of Sound.
Haven´t been since ... when? .... 1930?
