Recording from a PA
I have built 2 tube monoblocks PAs.
I wanted to listen to them and sonically decide what sounds better. I have about 4 variations to try out. One is with or without GLOBAL negative feedback etc. My issue is I'm having a hard time remembering and comparing what I'mhearing. Is there a way to record the output for later playback, making it easier to decide what sounds best?
Do you mean acoustically or electrically?
I would just play one for a week or two, then go to the next version for another week or two.
There's no point in trying to instantaneously A/B them. that's not how you listen to them.
You want a long term reaction.
That sort of stuff is done on YouTube all the time. You'd need a decent mic though.
But A/B comparisons are of little use. That's how bad speakers are sold in stereo stores.
Bad speakers can sound good in a brief, carefully set up comparison, but will be intolerable over time.
Same goes for other types of audio comparisons.
Koda,
I found this hookup diagram in the link you provided. Does anyone have some advice to select R3 and R4?
This: The two small resistors are the 22k:2k, the big one is the load for the amp. If you use the speaker as a load, you could omit the big resistor.
I don't think the pic you posted is relevant to the thing you want to test 🙁
