Need help designing a FM antenna
Hello guys,
I'd like to listen to the radio in my workshop now and then, but I can't get any signal, I hardly recieve one radio Station with my standart dipol antenna.
So I wanted to ask you guys, what is the best form of atenna, which doesn't take up a huge space, and what is the best way to build it?
When I was a teenager living at home I made a dipole from 300ohm twin lead wire that had legs approximately 150cm. It was up in the roof rafters, but it could grab the faintest signals in the Chicagoland area. Total cost was a few dollars.
It’s still in use today.
I do agree with @scholl - please try to straighten out your current antenna if it isnt. Also play with orientation - dipole are somewhat directional, particularly if you have the null pointed towards the transmitter.
Reactions: Osvaldo de Banfield
Best mount your dipole:
  • Vertically
  • Outside on the side of your workshop facing the local VHF transmitter
  • As high up as possible
When an aerial is mounted inside a building, wall insulation that is backed by silver foil can shield it from radio signals.
If the aerial must be inside the building, mount it high up so that it points through the roof tiles rather than through the wall.
Magnum Dynalab still lists a couple models:
https://www.magnumdynalab.com/fm-antennas-magnum/
The optimum solution is entirely dependent on particular circumstance. Are you in a downtown urban location, rural, suburban? Are all the stations of interest in one or multiple directions? Local or distant? Can you roof mount? I currently use a MD ST-2 leaning against the wall behind a large screen TV with a Sangean HD tuner. Almost all local stations run HD channels so multipath is no longer a factor.
I've had success with this cheap and cheerful design:
https://skegnessdx.blogspot.com/2014/12/the-infamous-faulkner-fm-loop-antenna.html?m=1
It's just a smallish loop and some coax, definitely worth a try.
Last time I used it was with a cheap (and quite deaf) software defined radio. I connected the loop to a cheap 20dB CATV inline amp and was pleasantly surprised by the signal strength and quality. The loop is directional, this came in handy when receiving 96.2 MHz from Holland (I'm in Germany) with a local station broadcasting on 96.5.
Reactions: Bigun and Plermpel
Hello guys,
Not cheap but good quality, see https://www.innovantennas.com/en/shop-page.html
The photos show enough detail about construction and the materials needed. Wooden boom for the simplest construction.
So I went with that design, because it was easy and cheap to build for me.
It works quite well with most of the stations but I have anouter question.
It don't get a very good signal quality from my favorite radio station.
It is broadcasting from 63° North-East, 55km away at 89,6Mhz horizontal with 8kW.
My car gets a perfect signal at the same spot as the antenna is right now, but the my Sony Reciever doesn't do as well with the loop antenna.
How exactly do I need to adjust the position so I get the best possible signal from that station?
EDIT.: How much would it help if I rebuild the antenna as a 85,5cm sqare and how bad would it affect the quility of the other stations?
Are you sure that your favorite station is horizontally polarized? Try rotating the loop 90°.
