ICEpower 1000ASP
Hi guys, i have two modules icepower 1000asp damaged with high voltage, so exposed some components. Anyone can say the code of part number of TA218 and TA210
Hi guys! I would like to ask for your help. I have two icepower 1000asp modules, on which a PTC thermistor on the SMPS primary side has exploded. So unfortunately the value is unreadable. Could someone help me with the identification of this? A close-up photo, where the code can be read, would be very helpful. Thank you in advance!
Mine is a 500ASP. In your photo, I can see the blue remnants of what looks like a MOV. In photos of the 1000ASP, it looks like a blue MOV in that spot. In my amp it's an Epcos S10K320. Likely the same part in the 1000ASP?
500ASP Epcos S10K320
1000ASP
1000ASP
Thank you for your reply! I disassembled the module to be able to measure it and, based on its position in the circuit, this should indeed be an MOV.
Hi All
Please help to identify the parts marked in the Ice Power 1000a module picture they are adjacent to the input connector. I have 2 modules one the parts have unfortunately come off and got lost in transit and one module with the parts populated. Most of the components are marked and identifiable, somehow the parts that went missing are not marked.
Below is the module with the parts missing in blue
