For collection only ( Buckinghamshire)
£160 for all 8 or £100 for 4
Just over 3kg’s each .
Aluminium heat sinks
Dimensions :
180mm
135mm
125mm
Please dm any questions
Dimensions :
180mm
135mm
125mm
Maybe you should put 2 aside and build a MoFo amplifier, these are the perfect size.
I could build myself a house from the ground up but an Amplifier is not within my skill set, I’d love to learn how one day.Maybe you should put 2 aside and build a MoFo amplifier, these are the perfect size.
Mate i think it would cost a fortune to ship with the taxes and dutiesDang. Wish you were in the US!
You would be surprised how easy it is to build, it’s for beginner with only a few components and powered via a laptop power supply, easy peasy. If you change your mind send me a PM.I could build myself a house from the ground up but an Amplifier is not within my skill set, I’d love to learn how one day.
Hi , what did you mean when you said if I change my mind?You would be surprised how easy it is to build, it’s for beginner with only a few components and powered via a laptop power supply, easy peasy. If you change your mind send me a PM.
Cheers
Andy
You build me a house and I'll build your 8 MoFo amps in return. Deal?I could build myself a house from the ground up but an Amplifier is not within my skill set, I’d love to learn how one day.
Hi AndyHi , what did you mean when you said if I change my mind?
Cheers
Andy
What I meant is if you decide to give it a go and build a pair of MoFo I can help you out.
Eric
🤣You build me a house and I'll build your 8 MoFo amps in return. Deal?
These would look the nuts on the right case .Hi Andy
Eric
I agree, the amp would be inexpensive considering you already have the most expensive part. With the heatsinks being as large as they are, you could actually simply let them sit on the table. Especially since you would be working with a laptop power supply and not mains.
Another option is the Amp Camp Amp which is specifically designed for first-time builders. It looks like you even have two holes drilled into each heatsink. DIyaudio store keeps the parts in stock.
Wow ! Now I see what you mean and yes very similar heat sinks if a little shorter, surely the heat sinks would be overkill though? Or are they class A amps ?For the MoFo, check p.18 of the MoFo document, doesn’t the heatsink looks familiar 👍
You can never have too much heat sink. Just more room to play with bias 🙂Wow ! Now I see what you mean and yes very similar heat sinks if a little shorter, surely the heat sinks would be overkill though? Or are they class A amps ?
Yep, pure class A. Sounds amazing.Wow ! Now I see what you mean and yes very similar heat sinks if a little shorter, surely the heat sinks would be overkill though? Or are they class A amps ?
The picture you see in the PDF file is for the regular MoFo which dissipate 32W (19Vdc@1.7A bias) at idle but there’s also the Big MoFo version which dissipate 60W at idle (24Vdc@2.5A bias) Maybe your heatsink are also suited for the Big MoFo.
