The first one is a thermistor to control inrush, can you show me one at mouser uk that I can get that would work the same.
The voltage rectifier I think is the same as this. If you could let me know. Thanks.
https://www.mouser.co.uk/ProductDetail/621-KBP06G
Are you sure about that first one? Looks more like a ceramic cap to me, 10nF.
The bridge you show at Mouser is much larger and will not fit your board. It is also much overrated.
Look for bridges for 1A or so, with a SIL case, although those are very rare, not sure you can still get those.
Check dimensions and pin spacing against for instance this one: https://asset.conrad.com/media10/ad...uggelijkrichter-sil-4-160-v-23-a-eenfasig.pdf
Do you know the voltage coming off your transformer?
Jan
Jan
Jan
Surprise! (Looks like a ceramic cap to me also! However using one wouldn’t harm anything, but the unit wouldn’t work.)
https://www.datasheet4u.com/mobile/924752/SCK-103.html
I learn every day!Jan
Hope you're well Ed!
Jan
You should be able to find a replacement with the resistance and power data for the original one in its data sheet. 10 ohms, 3A, 17W.I do know what it is. Looking for a replacement on mouser?
Mouser has these: https://www.mouser.be/c/circuit-pro...A&mounting style=PCB Mount&resistance=10 Ohms , you should be able to take it from there.
Jan
without schematic for the asked parts both ceramic capacitor and NTC (thermistor for inrush current limiting) is possible. In the meantime there are a very wide range of SMD parts to find without any letters (e. g. ceramic capacitors) or only values without brand name resp. logo (electrolytic capacitors).Are you sure about that first one? Looks more like a ceramic cap to me, 10nF.
Jan
According the attached image here most probably part from first image post #1 it is a NTC - like find under
https://imall.com/product/NEW-10PCS...ed/aliexpress.com/32744516051/567-30668212/en
and
https://www.yoycart.com/Product/214397529/
I see some of those rated as 17 JOULES is that right instead of watts?You should be able to find a replacement with the resistance and power data for the original one in its data sheet. 10 ohms, 3A, 17W.
Mouser has these: https://www.mouser.be/c/circuit-protection/thermistors/inrush-current-limiters/?current rating=3 A&mounting style=PCB Mount&resistance=10 Ohms , you should be able to take it from there.
Jan
- Can someone help identify these parts.
