What port diameter to choose
I am planning on building a subwoofer box for my home theater with a digital designs dd506d2
The design will be a double reflex chamber tuned between 20-25hz with one chamber around 5 liters of volume and the other one around 20.
I have a question about what my port diameter should be:
I was thinking about 65mm the port will be 1 meter long this way (which is fine) and the air velocity at 100 watts will hit the 17m/s mark
A the moment i have a 8 inch infinity subwoofer with a port thats 50mm in diameter. This subwoofer has noticeable port noice/chuffing. So I dont know if a 65mm port will be big enough in diameter (the surface area of this 65mm port is almost double of the 50mm port)
Any comments would be highly appreciated
Other information that can help me is telling me how big of a room i can fill with 60-70 watts of power which should make around 95db
Greets!
Well, wrote up misc. details with modded Hornresp sim and forgot to factor in the requisite band-pass filters, so will have to redo as time permits since it will make a significant difference re vent design. 🙁
