Protocol to rapidly "burn-in" a DAC?
This thread sounds to me like:
"I bought a new pair of glasses.
I want to burn them in.
What is the best technique for that?
Should I read a lot?
Fiction - non fiction - newspapers?
Should I watch TV?
What kind of program is best? .... action movies? .... Sports? .... cooking shows?
Should I watch continuously through them or open-close my eyes in 5 minute intervals?"
Quite an inapropriate comment @JMFahey . You expressed your opinion on the subject, which is 100% subjective fyi like the rest. And you write condescending remarks, which should say a lot about your opinion and personality in general. I respect knowledge and what is done, but i find it hard to respect people that value their opinion over the other ones, especially in such a manner.
Ok ...let's just use the products we buy...
Still...if you have to choose between two new products, of which one sounds better out of the batch, would you choose the worse one cause it will " burn in" and eventually get better than the other? Well...the better one will " burn in" too if you use it 😉
I vote with the 6V2 Zenners!Guess why?!
Did that as well a few times and found the slightly different (worse?) sounding one just sounded the same after a few hours. I blame it on the electrolytic caps. Let's agree over one thing: whatever the issue, it is always the caps 🙂
I accept that only with unipolar electrolitics, I refuse even the bipolars not just the nonpolar film ones unless we're talking about more than 3 decades older capacitors .The problem with electrolitics is that they have limited shelf life, but some are much, much better than the others in this respect. We might have an ideea how much time the product spent on the shelfs by production date, but it's not a rare thing that manufacturing companies are using 10...15 years old capacitors they had in stock or just bought from somebody else. Theoretically they can get reformated up to a degree which is always unknown, but if the rail voltages are +-15V and the csps are rated for 16V ,good luck with the reformating process done by just plugging the equipment to the mains!I'm not even sure how much better are the newer capacitors compared to some rubycons of the 80's or nichicons of the 90's.I bought a few hundred new bipolar nichicon muse in 2017 and had the chance to compare thrm to a 1990 stock and the 1990 stock didn't loose a single microfarad while the 2017 stock lost 5% of the value just by sitting at room temperature.The unipolar nichicon muse kz i bought from Mouser the same 2017 year lost at least 10% of their cspacitance if unused.
Is there any quantitative test data showing improvements in electronics' performance with age? Without this the entire concept is no better than religion.
Why would you need that if you can hear it and accept it? Do you ask for the datasheet when they put a pace maker in you? If there is quantitative test data showing improvements in your future performance?
This is about consumer stuff and besides that the effect is only when brand new and mainly in the first hours. Not after years. It happens anyway so just enjoy it or ignore it and tell that here if it makes you feel better. I think it's really odd to dispute something many others experience. Why would one deny that?
Reactions: MrKlinky
If someone does tests, its ASR. And according to their tests, khadas tone board is heaps and miles better than r2r nos dacs, which simply isn't true and by your ear you will notice the difference, of course if favor of the latter. Not everything is in the measurements. In my opinion, the use of both is the way to achieve greatness.
Because belief without evidence (faith, in other words) is not a reliable path to truth and progress in any shape or form. If we can understand why or how listeners hear or think they hear a difference we can actually move forward and not become mired down in personal revelation, however this seems adequate to countless minds and many subjects - maybe it's me that has it wrong...
Evidence-led science is the reason we live in the world we currently enjoy, and it is faith which divides families and nations, beheads infidels, and flew aircraft into the Twin Towers.
Please don´t misunderstand me: nothing against testing and improving our beloved Audio equipment.
But I am also realistic, and in the case of Digital equipment (include your DAC here), or Class D amplifiers, there is a widely known (if you specifically ask for it) but apparently ignored fact (in the sense of not considering it or giving it importance) which is the fact that you normally have a clock there, and gates (considered the simplest building block) and everything made out of them are being CONSTANTLY switching ON-OFF tens or hundred thousands times a second, full rail to rail or rail to ground 😱
Hint: "Digital" or "switching"
They are constantly working, Music or not.
They couldn´t care less what kind of Program is going through them, or even zero signal.
So, if anything, "burn in" comes from simply being turned ON, period, because then they will be working as hard, stressed as much, as with any program going through them.
I gave a general answer, but since it seems to be obscure or incomplete for some, let´s go into more detail:
I would like help to work out a protocol for rapid stress testing and possibly bedding in a 24bit 384kbit R2R SS DAC.
No signal induced stress.
In the rare event a DAC is going to fail I want it failing asap.
Ok, a worthy objective.
But then shake it, drop it on the floor, subject it to heat or temperature extremes, let it ON non stop for a long time, subject it to saline spray, corrosive gases in the atmosphere, strong electromagnetic fields (lightning storm/EMP/being near a powerful transmitter), feed it very poor unregulated Mains varying wildly, etc.
Program signal by itself? .... not so much.
I also want to test if playing in makes any difference to perceived sound for better or worse.
Try it if you wish, it´s your own time.personally doubt any electrical change will happen,but hey ....
If you want to argue or speculate about the actual reality of burn-in please go to .....
Please share your ideas on how to maximice rapid burn-in:
Does the idea "no such thing as burn in as far as sound is concerned" count as valid?
Or are ideas opposing a certain presumption pre censored?
Not much of a discussion then.
As of:
Is it good to have a power off time to form caps and do expansion-contraction stress testing?
Might be, but sounds overblown/overthinking to me.
Probably justified in interplanetary probe electronics, where device will be millions of miles away, and we expect years of service; otherwise .....
Is white noise with high frequencies going to speed up processing?
To activate all components is it necessary to play files with full volume range covering all the bit depths eg white noise from -140 to 0dBFS?
No and no, see above.
By the way, all components are being "activated", in the sense of "doing their job", all the time while it´s ON
Will a low resistance dummy load appropriate stress the output stage?
As mentioned by others, bad idea.
Please critique the approach below:
1. Play for 11 hours on and 1 hour off for a good ten days.
2. Play a special white noise 24/384 file at -140dBFS to -0dBFS, doing 2Hz-96kHz, alternating with a 2Hz-96kHz sweep
This exactly matches my reading glasses burn in protocol to a T, not sure why some might feel offended by that, the analogy is transparent.
3. use a low value resistor as a dummy load on the output, to stress the output stage and get the current flowing.
Bad idea.
4. A/B with a known stable DAC before and after. Ideally have two of the same DACs, burn only one in and listen blindfolded and A/B before and after.
Excellent idea and I applaud the double blind test.
It is exactly that clocks/XOs that, like the caps, need some time. I noticed this a few times when replacing XOs. Ah well, call it faith or what you want. Fo many it is a fact that new stuff needs some time to sound good/optimal whether you like it or not.
do you feel it's possible to rationalise or quantify what is happening within the equipment, or does it simply 'sound better to your ears' after some indeterminate number of hours' use? At what stage would you consider a piece of equipment 'burnt-in', acoustically, and why? I am guessing that you would agree that five seconds is too short a time, and five thousand hours probably excessive.
Further, how do you exclude personal psychoacoustic effects/expectation bias within your evaluation over time? I am at a total loss to explain my own changing and acoustic perception of my system from one day to the next; there is a good reason only a small part of the brain processes hearing compared with sight since our ears are a somewhat blunt instrument compared with most folks' simply spectacular optical processing and pattern recognition. As an example, very few people could hear a minimal change in pitch from one hour to the next but many could see that a picture is now hanging out of square.
You might feel I'm putting you on the spot - I am - but please trust me that it's not for the sake of ridicule, it truly is to improve my own and hopefully others' understanding of this oft-repeated but rarely explained phenomenon.
Bad idea.
I have a theory that double-blind ABX testing is deliberately avoided in audio reproduction since it would prove that most 'Golden Ears' are far from it! (Yes, I'm looking at you, Ivor Tiefenbrun...)
Like Dorothy, Toto, and fellow travellers in Oz were told in no uncertain terms, "Pay no attention to that man behind the curtain!"
