Dual Triode crossover
Would using an ECC83/12AX7 family double triode as a stereo pre-amp driver cause much, if any, cross-channel interference?
Similar question for using a 6AS7G double power triode?
I'm curious to experiment and see if a stereo single-ended amp could be made using just two valves (tubes).
Anyone tried this before?
Many thanks in advance.
It would be useful to realize that a stereo system does not require more than some 30...35 dB crosstalk attenuation. Many hi-end MM- and MC cartridges have only 25 dB.
It is possible, no problem in general, but for 6AS7G some 250 Vpp low distortion drive voltage is needed.
Reactions: Mission720
As mentioned above, you shouldn´t have any problem; layout, grounding and shielding will still be big factors avoiding crosstalk, but if you wish, I suggest instead of a 12A*7 , you use instead a very high quality ECC88, 6N2P, etc, which have "6.3Vac only" filaments, prewired from pin 4 to 5 (instead of dual voltage 12A*7 which uses 3 pins).
This not only liberates pin 9 but more important, they added a screen/internal shield between triode sections, grounded through pin 9 ... what the Doctor ordered 😉
75b6048a-6e0c-4beb-b86c-3aa2a6b07a93-jpeg.739608
Thanks - I have a "large collection" of 6N2P-EV. To drive the 6AS7G with sufficient voltage swing I was thinking about 6N1P-EV since that can take a higher B+ voltage. I appreciate the gain is significantly lower compared with 6N2P, so that's another factor.
Nice little amp.
Somewhat worried schematic does not show any filament reference to ground: neither center tap nor resistive artificial one.
Not even (ugh!) grounding one end of winding.
Nor do they tell builder to ground pin 9.
It's a shame the quoted power output is so low at 2.5w, I was hoping to get around 5w per channel.
You can get 4.5...5 W from one half of 6AS7G, but this require optimum operating conditions, which are about as follows:
  • Ua = 250 V (= some 370...380 V as +Ub)
  • Ia = 50 mA
  • Rload = 2k5 to 3k5 (see attached sim.)
  • Ug(ac) = some 250 Vpp
I have done 6AS7G SE amplifier, but used one tube (two halves) as the output stage. Power output was some 9 W. Attached my schematic too.
