hi everyone
Im looking for a Tractix Horn to fit a PR170M0
anyone have some experience and suggestions?
thanks
thanks
The tractrix is a horn with varying properties. What aspects of it are you trying to get the benefit of?
good questionThe tractrix is a horn with varying properties. What aspects of it are you trying to get the benefit of?
ive been recommended that tractix horn are a good match with PR170MO. K-horn bass bin xo around 300hz...
Ok. I can't imagine they wouldn't specify the cutoff frequency at the same time, unless they just got lucky... (Because sometimes a tractrix may be used to transition from wide to narrow and you want to choose where.)
Hi, I'm using the driver between 250 - 1200 Hz as part of a 4 way horn. Some info here Post in thread 'System Pictures & Description' https://www.diyaudio.com/community/threads/system-pictures-description.23208/post-6517066
How are you thinking of using them?
Rgds Barry
Rgds Barry
