Salas SSLV1.3 UltraBiB shunt regulator
I don't understand you?
Less current will help the Tx go more quiet I meant. By the way, if R-Core has fallen and hit or had strong transportation shake it can become loose. Especially if already mounted on a chassis. I had a 120VA R-Core it once came loose because of bad courier handling. I saw it had base frame metal teeth to keep it tight. Those went out of shape from the shaking and I bent them back to grip the core.
Yes I thought so.!
This is the sink you see above.
https://eu.mouser.com/ProductDetail/Ohmite/VRA-55-101E?qs=rI7uf1IzohTCxyg5G/7OyQ==
I also bought this one and used the clips off it. This one has a flat upper and so maybe could add some mass onto it
https://eu.mouser.com/ProductDetail/Ohmite/C220-050-2AE?qs=zRaq9JBfD9%2BFIZTL8whsYA==
I couldn't find the clip on Moiser.i guess I could have drilled and tapped it.
I also got this one to try...75mm long, but it is quite light
https://eu.mouser.com/ProductDetail/Wakefield-Vette/693-75?qs=vLWxofP3U2zqYvFO0uRJDg==
Have you tried with thermal padding in between? It might bring the temps down a bit further.
I tested UBiB 2 days ago quickly without heatsink.
100 Ohm resistor at each outputs to relief stress from output transistors.
UBiB worked and output voltage set.
Later I found cute small heatsinks that I used for Neg Pos M1 and different one for M2.
Pos M2 resistor became anomaly hot. I even burn a finger a little.
IR thermometer showed temp rised fast to 70 80 90 100! Celsius.
I turns out heatsink was close to pcb, it touched output pad of R1 and metallic part of M1 transistor. I didn’t use thermal pad.
Well.. nothing have died and UBiB still works.
I reset output voltage after 2 hours.
Pos is pretty stable at 18V.
Neg could drift from air to +/- 0.04 mV and then be back to 18V.
P.S.: I forgot to tell that my 5W 100 Ohm resistor that I used for testing was like about 115 Celsius hot. 10W with long leads might be more appropriate.
P.S.S.: Heatsinks for M1 was flipped upside down. So problem with heat sink touches near pads was solved.
