Need suggestion for speaker box enclosure
Greetings, this is my first time posting here
after some bit of lurking, I decided to make my own speaker. note that this is my first time, I just gonna use a cheap full range speaker. after some bit of research, I found this speaker which a local brand in my country (definitely not hi-fi, but it should be fine). since its relatively dirt cheap, I wished to give it a try (my budget is too limited so any recommendation of more expensive speaker r probably not possible for me)
https://jicspeaker.com/product/lb-04025/
my question is that this speaker got both High EBP and high QTS (above 1...I know...but please bear with it). so I'm still wondering should I go sealed or ported. and at what volume. I was I was thinking just to make an infinite baffle instead
best regards
Welcome!
Open baffle, IB (> 10x Vas = > 11.7 L) with lots of damping to 'taste' or same cab with an aperiodic reflex vent (53 cm^2) with the understanding that with a tiny Xmax, 140 Hz Fs it's not even going to cover the AM radio BW down low. 🙁
If just listening at low volume (~1 W peaks), a max flat alignment is ~25.14 L/~57.8 Hz, which can also be a (vented) TL with a small footprint.
Calc'd ~86.25 dB/W/m
Reactions: waxx
I see. so its better to be used as satelitte speakers coupled with subwoofer?
thank you for the response.
Welcome!
What GM suggests.
High Q, high Fs, should make for a reasonable midTweeter in an OB. Add woofers (now or later).
dave
