Sound card needed Recommendations please Budget limit
Joined 2007
I need a better soundcard with 5.1 or better outputs if I am going to use a computer based digital crossover for my subwoofer.
The motherboard only has stereo outputs
All I can find easily locally/via internet are the Creative Sound Blaster.
At around a budget of $150- to $250- am I going to do any better?
I'm probably not going to be doing much if any measuring etc using external microphones and only the Dayton DATS for driver interrogation
PCI-E motherboard and not a top of the line computer but OK
ESI GigaportEX may be an option. Also if your mobo has HDMI out, an HDMI LPCM audio extractor may work. Those are both external, not PCI-E, sorry.
Unfortunately the budget options are seemingly limited and of questionable sound quality.
BIG step up to Motu Ultra-Lite mk5, MiniDSP Flex Eight, and Topping DM7.
Way above my budget and way above my needs.
I just need some better playback options for the computer.
Nice gear but I'm stuck in the 70s and my main music system is vinyl oriented.
I have USB 3 so I could go external if I have to. but my desk is usually a mess and internal is less likely to get knocked/bumped/dropped by my wifes rampant cat
I'm using a Asus Xonar D2X 7.1 with 4x BB PCM1796 DAC. It's a really fine card, which is used about 25 - 35$/€.
review @ Guru3D
I've just bought the cheap Audigy Rx, simply because it was cheap and available right away.
But I can't get my little passive subwoofer to work and for some reason I can't get the SoundBlaster control panel to install so I can see what's happening.
Bought a new mini cable with the three layer pin and everything/
I would have bought the Asus if one was there for sale
I think I need a 13YO to assist me
