Dayton RS150P-8 port lenght?
i am building a new more advanced center speaker,but i am very unsure if my calculations about the port dimensions and the lenght!
I have 2 piece of dayton rs 150p-8 drivers,and 32 liters volume(without drivers calculated)
What can you recommend?
2"? 3" and ?
Hmm, a T/S max flat alignment is ~9.44 L, 56.6 Hz Fb, so dual = 18.88 L, leaving lots/too much? room left over, ergo will need to experiment with solid 'stuffing' to make the dual 2.5" dia x 10.125" long vents be correctly tuned.
Reactions: jkthn
I was thinking that the drivers and the ports are taking alot of space,that is why i build a 32l box,but maybe little too big,my thought is that it is better with bigger than smaller box.
I am not good in writing,i am from sweden 🙂
Well, either you or some translator program is doing just fine. 😉
A good plan that I always adhered to since it's a lot easier to 'shrink' a box than enlarge it. :headbash: :cuss:
Ok,if i have these port lenghts and size that you wrote to me,how too count volume that speaker and port will take ?
18.88l + speaker port volume? or is it not nessesary to count this? just a thought 🙂
