Slob with Full range wiring advice
Hi Guys
Going to experiment with XKR very nice XSD speakers. No wanting to confuse the thread there, thought it's better that I start anew.
Question pls : Have gotten 20pcs 8 inch woofer with Qts of O.99 with sensitivity of 87 db at 8 ohms each, will use 10 woofers per speaker. Full range is a Coral Flat 8 with sensitivity of 94/95 db 8 ohms.
How do I wire them up together to get 8 ohms if possible ? Will test out with single speaker connection first no bi amping
Ah yes, 9 per side will give you 8 ohms and +9.5dB sensitivity
8 per side can give you 16 ohms and +6dB, or 4 ohms and +12dB
10 per side gives 20 ohms and +6dB
12 per side can give 6 ohms and +12dB, or 11 ohms and +9.5dB
Yes woofers in the Slob with cones facing each other. Woofers will only do lows around 300 hz or so
Full range will face front. Due to speaker height. I've decided to try 3 slobs at the bottom with 1 slob sitting above the full range if I go for 8 aside. If 10 aside then 2 slobs will be on top of the full range
Many thanks again
how to get 9 per side if it excludes the full range driver.
If the fullrange driver only works above 300Hz then do not worry about it. It is by itself and the impedance will be 8 ohms above 300Hz.
Reactions: Alexium
Thanks again Allen but can't do 9 as slobs needs pairing to face each other so can only do 8 for 4 pairs or 10 for 5 pairs.
The reason I was thinking of 4 pairs is room gain but will have to test it out to know for sure. Re Full range if I can I will run it fullrange cause it sounds very good as it is don't want a cap to muck up the sound
Many thks again
You might have a problem with that. The SLOB will tilt with frequency and need equalisation differently to the fullrange. Levels and power handling will be different. You might be better without the SLOB if you want to run the fullrange full range.
Also, you won't get room gain.
